Bluetooth with 2 paired phones present
Discussion in 'Gen 4 Prius Audio and Electronics' started by GT4Prius, Apr 8, 2017.
  1. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    Anyone tried making a call from the car when it has two paired phones present in the car?
    Is it capable of connecting to two or more phones at once, and if so, how does the car decide which phone to use when you make a call?
  2. krmcg
    2,592
    2,390
    Whittier, CA
    One at a time. Seems to pick up the previous one used when two are in proximity.
    RCO likes this.
  3. Mendel Leisk
    38,726
    So if the only phone present is not the one previously used, but it is paired, the car will use bluetooth with that phone? That is improvement: our experience with 2 (paired) phones on a 2010, to switch to the second phone requires some work within the menus.
  4. aurelio
    aurelio Member
    72
    56
    Mexico
    You can pair many phones at once. In the Bluetooth phone setup screen you can choose between them to select which one will be used for audio and which one for phone calls. Only one will be used for each service.
    SM-T813 ?
    RCO, krmcg and Mendel Leisk like this.
  5. aurelio
    aurelio Member
    72
    56
    Mexico
    It will. At least mine does with my phone and my wife's. But the car should see only one when started. It will enable selected profiles in visible phone when it was first paired.
    SM-T813 ?
    RCO and Mendel Leisk like this.
