BMW may be changing their mind
Discussion in 'Diesels' started by bwilson4web, Mar 28, 2016.
  1. bwilson4web
    15,523
    Source: BMW Sticking With Diesel in the U.S. – News – Car and Driver | Car and Driver Blog
    January 6, 2016 - “We have no reason to give up on diesel in the United States,” he insisted. “It’s still one-third of the X cars we sell there, they’re strong on diesel. The customers that have had diesel cars from us are really diesel fans.”
    While one German newspaper has hinted that BMW has exceeded NOx emissions limits in real-world measures, tests by the California Air Resources Board and the EPA have not reported any irregularities from BMW diesels, and BMW has always insisted its cars have met all regulatory requirements.
    “The diesel systems for emissions in the U.S. and in Europe are more and more the same, so it’s not a problem of engineering for us to keep making diesels,” Fröhlich noted.
    In the United States, BMW currently sells diesel versions of its 3-series (328d xDrive sedan and wagon), 5-series (535d with rear- or all-wheel drive), X3 (xDrive28d), and X5 (xDrive35d). Diesels accounted for approximately six percent of BMW’s total U.S. sales in 2015, and the company did not see any drop-off in demand in the wake of the Volkswagen crisis.
    Holy Carp! Did you see the prices:
    • $39,850 - 2016 BMW 328d
    • $41,850 - 2016 BMW 328d xDrive
    • $52,650 - 2016 Mercedes-Benz E250 Bluetec
    • $57,350 - 2016 BMW 535d
    Source: At BMW, the Hybrid Future Prevails - News - Car and Driver | Car and Driver Blog
    The skeptics within BMW, those that question the merit of electrification and downsizing, and that define rear-wheel drive and straight-six engines as the core of the brand, seem to be losing out. Their cars still exist, but direction initiated by former CEO and current advisory board chief Norbert Reithofer is clear: For the next decade, BMW is expecting massive changes on the global automotive market, and the models will change accordingly.
    BMW has identified two areas of focus: Lowering fuel consumption and emissions—and the digitalization of the driving experience, including car-sharing, “accident-free” driving, new user interfaces, and the car as part of a “digital ecosystem.”
    The exorbitantly expensive launch of the i sub-brand and the i3 battery-electric vehicle, as well as the i8 plug-in hybrid, were clear signs that BMW is dead serious about tackling the future—as seen by the company’s visionaries. Both models were developed with great autonomy, by teams that took radically new and often costly approaches such as the carbon-fiber structure of the i models that “we would never be able to use for an M model,” as a company executive told us.
    While the i8 is selling at least as well as planned, the i3 is lagging significantly behind the internal projections. But these models are not an end in themselves: They are paving the way for a much larger family of plug-in hybrids that the company needs to meet ever-more-strict emissions targets.
    I looked at the i3-Rex but it has such a lame, range extended engine, it doesn't make sense. I like the body style and would consider a used one if it weren't for the lame engine.
    #1 bwilson4web, Mar 28, 2016
    49,488
    why would they give up on diesel? don't they sell the expensive high end epa sanctioned design?
    beemer buyers can afford and desire the most expensive tech, vs vdub drivers who consist mostly of unemployed college grads.
  3. Trollbait
    11,560
    The engine on the i3 REX isn't intended to provide full operation to the car, but as just a range extender to the EV. The intention as intended was that the driver would be aware they would be exceeding the EV range long before they got to a near dead battery, and they would turn the ICE on to keep the battery charge up, perhaps as early as the pack at 80% SOC, while still enjoying full performance from the car.
    CARB insisted on hobbling the software though. So US models can't turn the the ICE on until the pack is down to 15%. Which is why they have problems in climbing mountains and tall hills in hybrid mode. If a US model can't be turned back to European operating specs, I wouldn't even consider a used one.
    As for their diesels, yes, BMW didn't cheat. The BMW used on the West Virginia Tech study exceeded NOx limits on one test circuit, but the researchers felt no need to look further into it by running the car through the EPA test cycles, as they did with the VWs. Others were likely measured exceeding limits by onboard test equipment in other studies too. Guess what, gasoline cars have been measured exceeding limits by such equipment too. Like the MPG results, the regularitory tests don't completely mirror how cars are actually driven.
    bwilson4web likes this.
  4. bwilson4web
    15,523
    BMW would be better served by offering a Plug-In hybrid version of the i3 along with the i3-Rex. At least then they could optimize efficiency and even reduce battery range.
  5. Trollbait
    11,560
    A REX is an EV first, and is more of an EV than EREV.
    The i3 is a small, light weight platform to maximize the range and efficiency of the BEV model. BMW wasn't intending it to be a full function car in terms of size and range, but they knew a sub 100 mile range would discourage sales. So they made the REX version to assuage the range anxiety of potential buyers.
    Like BMWs, it is RWD, with the ICE and motor in the rear of the i3 REX. Part of the inefficiency it has in hybrid is because it is a pure series hybrid. If you want efficient and full performance in hybrid mode, you'll need a larger ICE with a transaxle that allows some parallel hybrid function. This will add weight, and take up some space in the cargo area. I don't think there is any space under the 'hood' for the power plant. Even if there was, the battery pack is a skateboard layout. Some of it can be removed to save weight, but the platform doesn't have a transmission tunnel. If BMW went FWD, that tunnel would still be needed in some form for the exhaust and emission equipment.
    For those that want an PHEV, BMW has the 330e.
    The REX concept of being mostly BEV with a range extender that provide ~75% of the car's power needs with the rest coming from the grid charge on longer than EV range trips is how I pictured the Volt working when first announced. I have a longer than typical commute, and the only time the i3 REX should need to use the ICE is during the very cold days of winter.
    A more efficient ICE might be had for a future i3 REX, but I believe size and weight were bigger concerns than hybrid efficiency. It would be dead weight for more time than the ICE in the Volt. On the hybrid to EV efficiency scale, better to tip towards the EV side for its design. The i3 is the most EV efficient BEV to be had now.
  6. bisco
    49,488
    bmw's problem, is that they are another high end builder, not willing to make a car for the masses. and that becomes our problem.
  7. Trollbait
    11,560
    True in the US, but they have more reasonable offerings in Europe.
    The 328d we get is just the 320d there, with corresponding lower price.
  8. bwilson4web
    15,523
    We'll have to agree to disagree on this:
    The control law needs to be:
    1. Start car and measure SOC_1.
    2. Begin driving and start ICE in idle, minimum fuel burn, warm-up.
    3. When ICE reaches operating temperature, measure SOC_2.
    4. Increase ICE to maximum efficiency operating point and bank power to traction battery.
      1. When SOC reaches SOC_1, stop engine, preserve heat.
      2. When SOC reaches SOC_2, start engine and move to maximum efficiency operating point
      3. Repeat 4.1-4.3
    Operating the engine at peak efficiency, power point compensates for the series electrical loss. The efficiency savings comes from the engine being off and avoiding the engine mechanical overhead.
  9. Trollbait
    11,560
    Which is how the i3 REX works, with some tweaks for creature comfort and sanity, "When the range-extender turns on, you cannot hear it at all from inside the car because it initially runs in the lowest of the three power levels. If you continue to drive at speeds higher than 40 miles per hour, it will kick up to the next power level and you can then hear a low hum from inside the car. If you are driving at highway speeds, it will jump up to its highest (28kW) power output, and then you can definitely hear it." - 8 Key Questions about the BMW i3 Electric Car | PluginCars.com
    The three power levels is what Audi settled on with their A1 PHEV prototype fleet. The even smaller Wankel engine originally ran at one set speed for efficiency. The constant, steady hum that was disconnected from vehicle speed proved to be unsettling to most drivers and passengers, though.
    At 75% SOC, it is possible to manually turn the range extender on with a model available outside the US. I would guess the ICE would shut down once the SOC hits some value above that. With the 3 power levels, the goal is probably more to keep the battery level around the SOC level it was at when the ICE was turned on than to recharge to battery. It can maintain 75mph cruising on flat roads for as long as it as gas. Go faster, climb steep slopes, or heavy acceleration that exceeds the ICE's output, and it draws from the pack.
    Unless the SOC is 3% or less, the ICE shuts down at stops and speeds up to 15mph.
    If not turned on manually, the range extender will kick on at 6% SOC. The US version doesn't have a manual control of the ICE, and it only turns on at this low charge point. Which hampers performance because there isn't more of a buffer in the battery when the car is on gasoline. Every PHEV out there now lets the driver decide when it is best to go into hybrid mode to save grid charge for when it will be best to use it. But PHEVs don't get the desirable CARB credits. So BMW agreed to so conditions to get some credits for the REX.
    In the US, the REX fuel tank is a half gallon smaller than the European one at 1.9 gals., and there is the lack of the aforementioned manual start of the range extender. Which makes the i3 REX like the first year Volt, but with an ICE that can't meet 100% of the car's potential power needs.
    So the ICE might run more often, and possibly at less efficient speeds, in the US, than if the driver at had more control over its operation.
    The efficiency of the ICE could be improved in later gens. Weight and packaging is likely more important for this one. The i3 BEV's high efficiency and range had much to do with the car's light weight. It and the REX use the same size battery pack. The ICE, generator, and attending systems drop the EV range from 81 to 72 miles.
  10. bwilson4web
    15,523
    Then three models:
    • i3 - BEV
    • i3-REX - CARB version
    • i3_PI - Plugin i3 with the EU control laws
    Living in a 'fly-over' state, the i3_PI with an efficient engine could replace our 03 Prius. It has similar interior and should be much better on the highway. But the i3-REX is just too hamstrung to appeal to me . . . of course I am thinking more along the Level 2 ECO with ATP (or something like it.)
  11. Trollbait
    11,560
    A federal version of the REX would have been nice, but the number, and populations in, CARB states makes it cheaper to just sell the CARB version now.
    It likely isn't hard to gain access to the European operation. It wasn't that hard to get EV mode in my 2005 Prius.
  12. El Dobro
    El Dobro A Member
    6,979
    3,214
    Fixed it. :p
  13. Chuck.
    2,766
    1,510
    Lewisville, TX (Dallas area)
    Wish I had the link, but still remember the main points. About twenty years ago, European governments encouraged the production of diesel cars. While the tailpipe emissions are more than gas ICEs, the fuel economy is 30% greater so overall CO2 is reduced. They were optimistic diesel emissions could be cleaned up. So diesel cars rose to 50% of the mix in Europe. Now it turns out it's not as green as believed.
    I found the link The rise of diesel in Europe: the impact on health and pollution | Environment | The Guardian
  14. bisco
    49,488
    i think grumpy concurs with you.
  15. wxman
    wxman Active Member
    620
    224
    Tennessee
    But NOx is just one of many pollutants produced by mobile sources. All other emissions besides NOx, e.g., VOC, CO, PM, PN, and most unregulated pollutants like benzene, are lower on average for diesel vehicles compared to gasoline vehicles. I really don't understand why these European officials are solely focused on NOX emissions.
    Even then, BMW diesel vehicles are doing well with respect to NOx emissions in Europe. In recent testing, one BMW diesel model had "real-world" NOx emissions than were below the regulatory limit ( Green Car Congress: Initial results from French NOx emissions testing of 100 diesels show high discrepancies between official and on-the-road results ).
  16. bisco
    49,488
    but it's more difficult to achieve in a moderately priced car.
    wxman likes this.
  17. wxman
    wxman Active Member
    620
    224
    Tennessee
    One well-respected damage model (APEEP) actually assesses that NOx emissions are BENEFICIAL in two heavily populated counties in the U.S. (looks like Orange County, CA, and Cook County (Chicago), IL).
    Nick Muller's Homepage (graphic on right side of developer's page)
    As a disclaimer, NOx does cause damage to public health and the environment generally, and I'm certainly not promoting additional NOx emissions, but it is not one of the more damaging emissions according to that source (ammonia, for example, has a maximum damage cost of $302,000/ton).
    Edit: Graphic loaded in preview, but not when I posted it. The graphic can still be viewed at the link above.
  18. bisco
    49,488
    as the protector of public health, the epa should be looking at all the emissions, and studying the health threats. seems like the science was finalized before it was finalized.
