Bob Wilson:Here's your copper content Bob:
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edthefox5, May 16, 2008.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    Hi Bob,
    Stumbled upon this other day. I think this is where your copper in your Amsoil ATF UOA came from. You were right about the additives but this should make you feel better that its not attacking motor field wire. Or maybe it won't make you feel better as it seems it has attacked your bearings/syncro's. I don't believe Redline uses much additives as it starts off with highest quality Ester base stock available. Additives are used to improve poorer base stock I believe.
    Transmission Oil Specifications (2) - International Mazda Forums
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Hum,
    I would think the motor/generator field coils are wound with enamel coated (insulated) copper magnet wire. If the enamel coating was compromised to allow oil to come in contact with the copper, it seems like the windings would short out.
  3. bwilson4web
    15,518
    Thanks!
    That also agrees with the other readings from the Amsoil ATF, notibly phosphorous. I could not tell where the copper was coming from but I sure could tell that it was there!
    Thanks for the reference. Now to find out where Type WS resides.
  4. triumph1
    triumph1 Member
    275
    What does this link have to do with ATF?
  5. edthefox5
    10,096
    4,805
    Clearwater, Florida
    Yeah Bob & I had quite a lengthy dissertation a while back concerning this very subject. He changed out his Gen 1 ATF with Amsoil ATF. Pulled a UOA and discovered high copper content.He was concerned that it was possibly conductive material from the motor windings. My position was the same as yours. If any motor winding was exposed to the fluid bad things would happen. The whole discussion is whether the WS fluid has some dielectric property to it to prevent this. My position is the WS fluid could be 100% dielectric and you'd still have a big problem with a compromised winding.
    I changed out my 07 ATF to Redline D6 which got alot of hey you can't use that it has no dielectric properties posters.Now the only question I have is based on this latest link is Redline oil pure enough that it has no EP additives (extreme pressure) which seem to attack copper. I sent Redline Corp an email asking about this and I will also pull a 2K sample on my Redline soon.
