Body Shop Recommendations
Discussion in 'Gen 2 Prius Main Forum' started by Family Hybrid, Sep 20, 2008.
  1. Family Hybrid
    Family Hybrid Junior Member
    87
    My wife's Prius was hit today on the R/R corner. Mainly sheet metal and bumper damage, but the area around the 12v battery has also been damaged. Does anyone have experience with the body shops in the Tidewater VA area? The other guy's insurance company is Progressive and I haven't heard great things about the body shops they pick. HELP!!
  2. Patrick Wong
    18,200
    6,474
    Sorry to hear about your damage. I don't have a body shop recommendation but encourage you to pick a shop carefully as it appears that the right rear quarter panel will have to be replaced, a pretty big job. It will also be interesting to see how well the new paint job will blend in with the old.
    Good luck.
  3. ivanbg
    ivanbg Junior Member
    Alexandria VA
  4. ivanbg
    Alexandria VA
    I forgot to mention but when the insurance adjuster comes around tell him/her that you want genuine Toyota parts.
    Also get a few estimates from local shops and ask if they will straighten the panel and fill the waves and imperfections body filler( aka Bondo or mud) or replace it. I would go with the one that replaces it.
  5. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Family Hybrid, there's no need to go to a body shop. You might be able to fix this yourself! I had a similar accident in the same spot a couple of months ago. You'll need some car polish and a plunger:
    1. Spread some car polish over the damaged area. The car polish helps create a better suction.
    2. Push in the plunger with your hands, turning it inside out, rather than pushing it against the car first.
    3. Put the plunger up against the damaged area, creating an airtight suction.
    4. Gently pull. The plastic should pull out.
    The reason this works (for me at least) is because the Prius material is plastic and very formable. However, your success depends on how long ago the accident was (how long the plastic has been pressed in) and how well you can create a suction. When it works, however, it works incredibly well! Mine looks as good as new. In fact, it looks even better than before the accident, because I used car polish! Most of all, this can save you hundreds of dollars.
    Good luck!
