Body Side Moldings Removal
Discussion in 'Gen 5 Prius Main Forum' started by REBobBecker, Apr 14, 2024.
  1. REBobBecker
    REBobBecker New Member
    Minneapolis
    2024 Prius Prime
    I'm curious. Has anyone removed the body side moldings from a 2023-24 Prius? I'm assuming they're attached with tape, but I'm not sure. Was the removal easy; hard? Was there any noticable marks left on the paint? I'm not a fan of the moldings. I'd much rather park as far from other vehicles as possible and keep the smooth lines of the car as designed...without moldings.
  2. HacksawMark
    HacksawMark Active Member
    437
    284
    Oregon
    2023 Prius Prime
    XSE
    A hair dryer or heat gun with gloves would work. Be careful if using a heat gun and they can get really hot. I used the wife's hair dryer to debadge the rear trunk lid. You will spend more time getting the glue residue off then you do taking off the side molding. I used Goof Off to remove the residue.
    REBobBecker likes this.
