Boot/trunk not opening :(
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2006GuitarGuy, Jan 18, 2025.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey guys!
    I have a gen 2 (2006), while trying to open the boot the tailgate was pretty much crumbling in my hands, like many people before me, I used duct tape to hold it up:
    Then I puchased that piece from Amazon, as well as part #1 (see below pic) from China, installed #1 on the tailgate and attached it to the car, I did not connect #2
    but when I try to open the boot, nothing happens :(
    I tried it with the old switch (#1) as well and it still won't open :(
    Question 1: What could be the problem? Please advise
    Question 2: The duct tape has left some white residue as can be seen in pic 1, best way to take that out?
    Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    11,995
    2,119
    Durham NC
    Pick the tailgate back up I believe you have to plug in number two The button with the rubber over it in the center of the car that wire goes over to the button which is number two and then the plug off number two goes to the car so that's right right now with that disconnected you have no clicking no noise nothing plug that up and now push the button and you'll hear the trunk lock release it clicks.
  3. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Traces of adhesive tape are easily removed with brake fluid. But be careful! Apply a small amount to a rag and wipe off without applying much force. The trunk may not open because the antenna does not detect the smart key, and the signal to open the door does not come.
  4. Tombukt2
    11,995
    2,119
    Durham NC
    Maybe because it's unplugged look at your number two plug again I'm not going to pull the back panel off one of my trunks right now but I'm pretty sure that needs to be inserted to get power to the switch so you have a chance of the motor working and you lifting the trunk I do believe The car that I have the trunk apart on that fascia panels missing so I can't tell you but I'm pretty sure that needs to be plugged You have no power going to that switch right now where is it coming from? When your manually pushing that button if the car is unlocked like you just got out of the seat and walked to the back of the car SKS and all that should have no count or function for you to get in the trunk That's when you're locked at Walmart and you walk out to the car with the remote in your pocket if you have that feature that has no bearing as of right now I don't believe.
  5. Prius2006GuitarGuy
    Sweden
    Hey!
    Sorry for my late reply, I had notifications turned off :(
    I tried plugging in the original that's unfortunately not working. Plus I think the replacement part is faulty, it didn't come with the #2 sensor, it was just #1, after going back to alibaba and Amazon I see there is a different model with #1 and #2, I'm looking to picking that up but my only fear is maybe something else is the problem and the new (updated) part will still not work :( Any advise on how to check if that's the problem?
  6. jonsey1886
    jonsey1886 Junior Member
    Roanoke
    #2 isn’t a sensor, it’s the connector wire for the hatch switch.
    It also completes the circuit for the rear sks antenna-which is what receives the signal from your key.
    There is also a 4 pin connector adjacent to the door striker that is connected to the motor and makes the motor work, as well as the lock, unlock, and door ajar functions.
    It can become corroded from water intrusion due to a failing cargo hatch seal.
    #6 jonsey1886, Feb 2, 2025
