Boot (Trunk) Roller Blind
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by IanIanIanIan, Jan 28, 2014.
  1. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    My PiP roller blind cover does not roll up very well, it is very sluggish and droops when retracted. My old genII was much better retracting and storing neatly.
    I have dissassembled it but I have no idea what is the best tension to reset it to. I have given ten turns of the spring but it is not enough. I shall have to have another go.
    Has anyone got any advice?
  2. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    Mine was the same. I had it replaced under warranty. The new one was a little better initially, but is now acting the same as the original. I think it's a design flaw.
    49,493
    i've never used mine. it's underneath, so, i don't know.
  4. markabele
    5,084
    1,782
    Nebraska
    Same here. Haven't used mine in a long time.
    If I had to venture a guess, I would say that you might be able to prolong it's useful life if you don't use it when it's really cold or really hot.
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    I too noticed the difference between my '06 and the PiP. The older one seemed stiffer and easier to guide into the slots which hold it in place. Change for the sake of change?:rolleyes:
  6. Bucky35
    Bucky35 Junior Member
    37
    NorCal
    I had to take apart the cover on my GenII to clean it. I wound it 15 turns and while it is serviceable as is, it's not as tight as it used to be. I'm guessing at least 20 turns for being taught.
  7. elife
    elife Junior Member
    37
    Northern Virginia
    You guys must live in really safe places as I often have "stuff" in the back of the car that I do not want on display i.e. camera or binoculars. Don't want to invite trouble so I pull the roller over it.
  8. bisco
    49,493
    i leave stuff uncovered back there, but i wouldn't leave electronics, it's not that safe!:cool: i have seen reports of people who go Christmas shopping, take stuff out to the car and go back in to shop. when they come back out, the trunk is open and all the presents are gone.
  9. markabele
    5,084
    1,782
    Nebraska
    There are very few times of the year around here where it is ok to leave expensive electronics in an unheated or uncooled car.
  10. Chris_SoCal
    Chris_SoCal Junior Member
    44
    Wildomar, CA
    Thieves just don't have much Christmas Spirit...
  11. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Well the first thing I noticed was the cargo area tonneau cover on the PiP was about half the weight of the Gen II. They make a LOT of things either harder or flimsier than the Gen II. And all of these are for saving weight. I guess it adds up. I use my tonneau cover all the time, less area to heat or cool.
    iPad ? HD
  12. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Dismantled and rewound, 20 turns works well. Easy to do as well.
    usbseawolf2000 likes this.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Mine retracts so weak as it gets colder. I think I will add 20 more turns as well.
  14. IanIanIanIan
    IanIanIanIan Member
    152
    56
    2013 Prius Plug-in
    Just 20 turns from slack.
  15. DadofHedgehog
    DadofHedgehog Active Member
    681
    281
    northern Virginia
    Good thread - been wondering this myself. Thanks y'all!
