Bosch Double Iridium spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Jul 10, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,875
    822
    Wanted to try these out and just took them out today to see what they look like.
    Installed 12/22/18 @ 170,768 miles
    Removed 6/10/20 @ 182,694 miles
    11,926 miles on the plugs.
    These were purchased at Pepboys. 20200710_152230.jpeg 20200710_151749.jpeg 20200710_151809.jpeg
  2. johnHRP
    johnHRP Active Member
    417
    133
    tally, fl
    Look at mine after 100k miles, It is original Denso SC20HR11 (old) and new one Denso SC16HR11 (updated hotter range). It is almost identical within less than 1/10 mm . Double Denso Iridium is not double iridium because the ground is still platinum, just like in Denso or NGK. IT is not bad but I prefer OEM japan DENSO from local stores like Advance Auto, you can use online coupon 40% off and pick up locally.
    AzusaPrius likes this.
