Botched Jumpstart, reversed polarity,2006 gen 2. Please help.
Discussion in 'Gen 2 Prius Main Forum' started by Tangray, Jun 17, 2017.
  1. Tangray
    Tangray Junior Member
    Hi all. I'm in the UK. As it says I cocked up my Jumpstart after returning from vacation for two weeks.
    After researching on here to look for solutions and what to do,
    I have repaired the 100amp DC fusable link,
    Replaced blown fuses ( dome, eps and battery +)
    The inverter pump is pushing fluid around,
    I have 12.1 at battery and 13.7-8 in ready mode (battery now on charge)
    Seems to be running ok,hybrid system working and recharging system.
    Had codes read and cleared, left with C1310 and P0a09.
    Red triangle vsc abs and on display battery and hybrid lights on.
    So your thoughts please on what to do next, I am on a very limited budget, so diy solutions are my way forward..
    Many many thanks for your anticipated response's......
    49,401
    have you disconnected the 12v to reset everything?
  3. Tangray
    yes have got the battery on charge at the moment,so will find out soon ...
    Cheers now...
    49,401
    hopefully, the inverter isn't fried, but i think salvage is reasonable.
  5. Tangray
    Just tried again , battery at12.8, but all the same lights remain on.
    In ready mode 13.8 at the battery, and shows system charging on display.
    So would this mean the inverter is working ?
  6. bisco
    49,401
    not positive, but i think so. can you drive it?
  7. bisco
    49,401
    what are you reading codes with?
  8. Tangray
    Yeah it drives ok, don't know the make of the scanner but it's one of these iPad size ones, went in to all the menus that I could see a friend of mine at the local autostore did it for me
  9. bisco
    49,401
    it may or may not give you the correct codes.
  10. bisco
    49,401
    if it drives fine, and charges properly (both batteries) and mpg's are okay, kind of a head scratcher.
  11. Tangray
    I think it's a capable one, if he knew which ones to try , it can force open relays and the like,and do full system checks ...
  12. Tangray
    Yeah my thoughts too, I got no hair left now lol, thanks for the help...
  13. Patrick Wong
    18,200
    6,472
    Odometer reading?
    DTC C1310 is logged by the skid control ECU and points to a fault with the hybrid control system.
    DTC P0A09 is logged by the hybrid vehicle ECU and points to a DC/DC converter fault: "Open or GND short in NODD signal circuit of DC/DC converter".
    Either the NODD wire which connects the hybrid vehicle ECU to the inverter has a fault, or the inverter needs to be replaced.
    I suggest you subscribe to the Toyota Europe techinfo website so you can access the factory repair manual info which shows you how to find the NODD wire, measure continuity, and if that wire is OK then the inverter is recommended for replacement.
    Since you are measuring 13.8VDC when the Prius is READY, hopefully you do not need to replace the inverter. Good luck.
  14. Tangray
    Patrick thank you for that info,
    Firstly do you believe I would be ok to drive short distance's without causing further damage ?
    Second I've downloaded a PDF of the wiring showing the NODD wire,am I correct in thinking this is under the inverter cover,and would require the HV battery to be disconnected to allow inspection. or is there a associated relay or connection prior to it I should try first .
    Thanks again...
  15. Patrick Wong
    18,200
    6,472
    Yes, you could drive the car without causing further damage if in fact the inverter is producing 13.8VDC on the 12V bus.
    Yes, you have to find the wiring harness connector at the inverter and good safety practice would include removing the traction battery interlock first.
    Andyprius1 likes this.
  16. Sushant Shrestha
    Sushant Shrestha New Member
    6138 rosehill dr alexandria
    While jump starting my toyota prius i mistakely reversed polarity and the dash board is not showing anything except the head lights are turned on and the signals too but the display is not poping up what should i need to check ??
  17. bisco
    49,401
