Both accessory receptacles on same fuse ?
Discussion in 'Gen 2 Prius Audio and Electronics' started by grathke, Jul 11, 2009.
  1. grathke
    grathke New Member
    16
    St. Louis
    2008 Prius.
    Does anyone know if both 12v accessory receptacles (below glove box and center console) are on the same fuse.
    The one below the glove box is not working when the Prius is on, but the one in the console is. If they are on separate fuses, where is this one located.
    Thanks
  2. dogfriend
    7,512
    1,185
    Carmichael, CA
    I have the 07 wiring diagram which should be the same as 08. There are two separate fuses, both are 15A, both are located in the same fuse box inside the car under the instrument panel. The two 15A fuses are in position 19 and 21.
  3. grathke
    grathke New Member
    16
    St. Louis
    Thank you so much.
    Glenn
  4. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Where is the "Instrument panel"? I blew both power fuses and I need to change them now.
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    Instrument Panel = Dash
    Look under the drivers side dash. See #2 location below.
