Both Headlights not working
Discussion in 'Gen 2 Prius Main Forum' started by orahm, Jul 2, 2008.
  1. orahm
    orahm New Member
    17
    Maui, HI
    Hi everyone, I have a problem with my headlights. They both stopped working all of a sudden. The first setting and high beams still work. Just the regular low beams are not functioning when they are set to on. Did anyone have this problem before? I checked that the fuses for right and left are still good, and they are. I also checked to see if the headlight relay doesn't work by switching it with the identical parking controller relay. And this also works. I believe I have HID's but I'm not 100% sure because I got the car used.
    Any help or hints are highly appreciated.
    Oliver
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    If you have HID headlamps, on the black plastic cowl at the front of the engine compartment you will see a yellow high-voltage warning sticker near each headlight. The HID lamp is switched from regular- to high-beam by a mechanical shutter that changes how the light exits the lamp housing; the light itself doesn't change in intensity.
    From what you say, I think you DON'T have HID headlamps. I think you have regular halogen lamps and the low-beam filaments of both bulbs burned out at the same time. I don't know why they would do that.
  3. Patrick Wong
    18,200
    6,472
    Hi Oliver,
    The first issue is to confirm whether you have HID lamps or not. If you have fog lamps, then you also have HID. If you don't have fog lamps, then you have halogen lamps.
    Assuming that you have halogen lamps, that all related fuses are good, and that you found both low beams to have simultaneously failed, perhaps the headlight flasher switch has failed?
  4. orahm
    orahm New Member
    17
    Maui, HI
    First of all many thanks for the reply. I checked for the high voltage sign and I do have it. I also have fog lights although it looks like the person before me switched the original to after market blue ones. This means I have HID lights.
    How do I go about troubleshooting the lights. It just seems weird that the both high beams still work and a the same time both low beams don't.
    Does anyone have any experience with HID's.
  5. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    O.K., orahm,
    You say you have foglights [which could have been installed aftermarket by a previous owner (if you're not the original owner---especially where you say the bulbs are blue---but the fogs could be original & just the bulbs chg'd to blue)]. You also say though that you have the high voltage warn'g labels, which would also really tend to indicate you have the HID's. However, since you say that the 1st switch position (the park'g lights is what you mean?) works & the high beam position (you mean the blue indicator light on the dashboard?) works the headlights, but you have no headlight low beams. Then they can't be HID's if the headlights go out in the normal "headlght-on" position, since whether in the high or low setting the bulbs still glow the same brightness (only a shutter moves down to cut off the top of the beam in the low beam setting).
    How or when did you check out your lights (daytime or nighttime---it's better to check at night)? In front of a verticle surface (like a garage door) or look'g forward on a road surface at night? If you have NO headlight glow at all (stand'g outside the car) in the low beam position, then you likely DON'T have the HID's. If you do have the bulbs glowing in the low beam position, but from inside the car you can't seem to see anything on the road ahead (other than what looks like the dim glow of the park'g lights), then I suspect that your HID's are O.K. but that the headlight leveling sensor (from the rear axle to the car body) is defective & what normally hapens then is that the headlights dip so low that in my case I could only see about 20 ft ahead & everything beyond that is pitch black. You usually see a definite line across the road dividing the illuminated area from the pitch black, but in your case your lights may have dipped even lower (or you sit low in the driver's seat) so that you can't even see that line on the road from inside the car & that's why you think the low beams are burned out (but as we already discussed, there are NOT 2 filaments in an HID bulb).
    You don't say your model year or your mileage but you did say "the person before me", so I don't think your replacement of that sensor (& the required aiming calibration after the replacement), if that's what your problem is, would be covered under warranty (since you apparently bought it used) unless an extended warranty was purchased by the original owner & he transferred that warranty to you (that can be done) or you bought it "certified, used" from the dealer & an extended warranty came with it.
    If this is the problem & it's not covered, the upgraded/re-designed replacement sensor (make sure it has a suffix letter "G" after the part number on the label) retails for around $300 (accord'g to somebody else's price check---mine was covered for free so I never got to know the part price personally). It was just an internal corrosion problem that some have posted their dis-assemly of & repair of (with pictures) here on this site. The removal & repair is not hard, so you've really got nothing to lose by trying it yourself (if it is NOT covered by a warranty situation), or you could just buy a new one (only with the "G") & put it in yourself. Either way you could also get lucky with the headlight aiming (after the repair/replacement) & not need to go to the dealer to pay the labor for the aiming calibration.
    Ken (in Bolton,Ct)
  6. greylar
    greylar New Member
    283
    38
    Montana
    If they are HID and they are going out when on low beam then my guess would be a problem with the switch on the steering column. Try putting it on low beam and then jiggling it around to see if you can make it work.
    G
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Do you mean the rotating headlamp switch on the end of the stalk? The high/low switch only moves the shutters on HID headlamps, so while it is possible that a bad switch could work in the high position but not the low position, it's not a likely failure mode.
    Tom
  8. greylar
    greylar New Member
    283
    38
    Montana
    I realize that but the light stock does turn on and off the lights and it is an easy thing to check.
    G
  9. Ct. Ken V
    535
    57
    Bolton,CT
    qbee42,
    I tend to agree with you that it probably isn't the control stalk switch that greylar suggests, but until orahm checks back in here & answers some of my questions (in my 2nd paragraph of post #5) we can't really guess any further. We really have to know how he came to the conclusion that the low beams aren't work'g. Are they really not even light'g up at all or are they indeed light'g up but just tipped so low (because of the adjustment sensor in the rear) that he just can't see any light being projected ahead on the road?
    I sit tall enough in the seat so that when I had my problem with the sensor I could see the demarkation line between light & dark on the road ahead, but it was so close ahead that I didn't feel comfortable driving in the country near my home that has plenty of deer crossing the roads at night. I could only drive at 5-10 MPH comfortably. If I put the switch to the high beam position, then I had visibility equal to or a little less than what I was used to when the low beams had been work'g right. I'm really lean'g towards my scenario, especially since he said the fuses were good too.
    Ken (in Bolton,Ct)
  10. qbee42
    18,058
    3,074
    Northern Michigan
    Ken, just guessing, but the auto leveler is likely the problem. The low beam cutoffs are so sharp that it's hard to tell the lights are on if they are poorly aimed.
    I'm guessing you will win the prize.
    Tom
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Good point - might as well check the easy ones.
    On the other hand, I think he should start troubleshooting by replacing the hybrid inverter. :D
    Tom
  12. orahm
    orahm New Member
    17
    Maui, HI
    Many thanks for the very thorough reply. Here is some more information: The vehicle is a 05 with package 6 I believe. I can't tell for sure because I got it on ebay and it has a salvaged title. The car's been working perfectly over a year now, including the headlights till 2 days ago when the low beams went out. I hope I don't have HID's then it would be easier and cheaper to fix, because I obviously don't have any warranty any more. All I want is to drive at night without getting a ticket. The fog lights are the really cheap led ones. They have to be aftermarket. They function correctly. I'm going to check at night how the highbeams function they way you explained it and get back here. Before that I'll also wiggle the switch on the stearing wheel and see if they work. I'll be back here with more info as I'm going to check it out this afternoon. I really appreciate the help a lot.
  13. orahm
    orahm New Member
    17
    Maui, HI
    I can verify that the low beams are totally off. I got outside the car with the switch on low beam and they are totally off. High beam is totally on. The parking lights, (they are located above the beam lights and are orange are also working, so are the fog lights) I had my girlfriend operate the switch in the cabin as I was listening to the switching relays in the fuse box. I also took the headlamp and dim relay out and checked it with an ohm meter for continouity. They both seem to be good. The car has 63000 miles on it. With this given how do we really verify if I have HID"s or not.
  14. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    Not sure if anyone has explained this clearly yet, so here goes.
    If you have HIDs, there is only one lamp element for both high and low. When you switch from low to high all that happens is a small shutter moves to unblock the upper part of the reflector. There is no change in the lamp. This is why it seems odd that they would only work on high-beam.
    You can see this shutter moving, it's the just behind the bullet shaped guard in front of the lamp. The other clue to HIDs is that when you turn them on after they have been off for a while there will be a bright flash followed by a slow (about 5 second) period where they start dim and brighten up. They may also appear blueish compaired to halogens.
    If you really have HIDs and they do't work for low beams then there is clearly some sort of control issue, either with the stalk or the wiring (You said it is a salvage, the headlights may have been cludged together).
    If it's got halogens, it could also be two burned out lowbeams. Stranger things have happened, and sometimes you don't notice one headlight out until the second one goes.
  15. orahm
    orahm New Member
    17
    Maui, HI
    After visually double checking the headlights, I believe I don't have HID's after all. I can see H4 12V 55W written on the metal ring of the bulb housing. the bulbs are blueish glass. I can't see any shutters move also. Maybe they did burn out at the same time. I'm going to try to get one of them out of there to check. I read that can be a little tricky as well.
  16. KayakerNC
    KayakerNC Member
    399
    Eastern North Carolina
    DIY section of manual has procedure (with pictures) for replacing non HID bulbs. But why would a Hi Voltage warning have been there?:confused:
  17. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    Those are definitely not HIDs From the blueish tint it sounds like the previous owner put some aftermarket super-blues or something similar in there. Some of the super bright halogens are known for not lasting very long, and ofter burn out around the same time. Hope that's all it is.
  18. orahm
    orahm New Member
    17
    Maui, HI
    You guys are absolutely right. This bulb is probably not more worth than 10 bucks. I'm heading over to the auto part store to get a higher quality one right now. I'll get back to confirm that this was the problem. Many thanks to everyone. I learned a lot about my car and HID's vs halogen lights.
  19. orahm
    orahm New Member
    17
    Maui, HI
    I got the job done. Just like you said both low beams were burnt on the both cheap aftermarket bulbs. For less than 40 bucks I got a set of better quality ones and put them in according to the other thread. I want to thank everyone. It saved me a trip to the mechanic and I learned a lot.
  20. patsparks
    10,664
    567
    Adelaide South Australia
    Sounds like the first globe went and surged the second.
