Both KEY FOBS not working
Discussion in 'Gen 2 Prius Main Forum' started by fruitydog, Oct 27, 2020.
  1. fruitydog
    fruitydog Junior Member
    berkeley
    Neither of my fobs unlock the doors by clicking the fob buttons or automatically when up close
    to the car doors. The fobs also won't start the motor unless inserted into the dash slot.
    The doors will lock mechanically though. I am driving the car alot less so could the car battery
    be a factor, although it did start once the fob was in the slot?
    2005 Prius 44,560 miles
    Thanks for any suggestions.
  2. Calimobber
    Calimobber Member
    94
    82
    Death Valley
    Little button under your steering wheel. It disables the wireless function.
    Pixel 4 ?
  3. Aegean
    Aegean Active Member
    428
    187
    Alexandria VA
    The little button disables only the proximity function. ( ability to start engine or open door with key in pocket). The remote buttons for lock/unlock the doors should continue to work no matter where the little button position is.
    If both remotes do not work anymore I would start on the car end and not on the remotes. Except if you did something to both remotes at the same time like washing them or putting them in a strong magnetic field.
  4. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    dead remote batteries ???
  5. fruitydog
    berkeley
    sadly, it was not the little button under the steering wheel. next step is trying a new fob battery. fingers crossed
    that by coincidence both fobs are simply dead. the backup one could have been dead a while just sitting in the drawer.
  6. fruitydog
    berkeley
    turns out both fob batteries were dead. thanks for all the supportive replies.
