Both lowbeams stopped working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JaymzB0nd, Feb 7, 2012.
  1. JaymzB0nd
    JaymzB0nd Junior Member
    68
    CA
    I searched the forums and Google in general but couldn't find anything about this on Gen 3s.
    Started my car this morning (2010) and both low beams aren't working. When set to on, only the daytime running lights come on (and yes I made sure the light switch was turned all the way). High beams work fine. Turned car off/on but still no good.
    Before I take the car to the dealer, I was hoping someone here could have a cheaper fix. My car has halogens, not HID. Thanks.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    There are no DRL's on a USA 2010 Prius. Also, 2010 had no HID's. The Prius V for 2010 had LED's.
    Check and see if there is a fuse for the headlights, if there is, maybe it's blown? Haven't heard this problem with the Gen III.
    Also, moving this thread to the appropriate forum.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Look in your Owner's Manual for the fuse description section. There is a fuse in the engine compartment, #19 - P/I 2, that is for the low beam headlamps along with the horn and a few other items. Check to see if the horn will blow. If not, it is most likely this fuse has blown.
    Wimberley2 likes this.
  4. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    If not the fuse, it may be a problem with the stalk switch.
  5. JaymzB0nd
    68
    CA
    Thanks guys. I checked the fuse before I went but it looked fine.
    Ended up going to the dealer and being told it may cost as much as $117 just for figuring out what the problem is. Fortunately they messed around with it and found out quickly that unplugging and plugging the bulbs back in made them work.
    Bad news is they don't have any idea why the lights stopped working but good news is they work fine and there was no charge for the fix.
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Glad to hear you were able to get the problem fixed.
  7. ToesF15
    ToesF15 New Member
    So I have a 2010 Prius III with 45,600 miles on it and had THE EXACT SAME THING HAPPEN - BOTH low beams went out at the same time. Having read this post, I tried to disconnect/reconnect the low beams to see if that would work. It worked indeed, only I didn't have to totally disconnect the headlamps to make them work, really just slightly pulled out on the connector (with car running and headlamps on) and presto! they started working. I had to do each one individually to make them work, and the passenger side was a real b--ch to access - I used a pocket knife to get it slightly disconnected - you'll see what I mean if you reach in there.
    I posted my mileage cause I'm wondering if this is a Toyota trick to make folks go in for maintenance shortly after their warranty runs out....
    Two days later the low beam headlamps are still going strong.
    BTW, the fuse for the low beams is connected to the horn and the backup lights so its very easy to verifiy if its a fuse problem (it wasn't).
  8. Jon S
    Jon S Member
    185
    84
    The Aloha State
    maybe the connectors were getting oxidized...
  9. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Had the same thing happen to me at about 35,000 miles. Took it to dealer and they replaced both bulbs under warranty. I questioned them about both going out at same time, they said they likely went out at different times and I just didn't notice until both were out. Wish I had known that bulbs were under warranty as I replaced both (not at same time) on my 04 between 20,000 and 25,000.
  10. muelled
    muelled Junior Member
    Washington, DC
  11. muelled
    Washington, DC
    I had same problem when my 011 Prius was 2 years old. Both lo beams were out. both bulbs replaced, but I find the low beams give very little light on the road ahead. I think it might be alignment, Im pretty sure they did not go out at the same time, but I failed to notice any difference at night. They both just give very little light in front of the car
