Bottom of car way too low
Discussion in 'Gen 3 Prius Main Forum' started by nudriver, Aug 9, 2018.
  1. nudriver
    nudriver Member
    247
    28
    los angeles
    One of the biggest flaws of the Prius's design is the fact that they made the car too low. There is one curb cut in particular that I can't avoid and when I drive over it I literally get stuck. People have to get out of the car for me to continue forward! I used to try to avoid dips but now I just run over them at whatever speed I happen to be traveling. The bottom of the car must be beaten up pretty good by now. What kind of protection is under there?
    Katherine28, Starship16 and bisco like this.
    51,141
    there's a full aero cover, or, whatever is left of it.:p
    Starship16 and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Ah the wonderful sound protection of plastic:eek:.
    Have you tried taking the jump at an angle?
    Be glad you don’t have a gen4 as I believe they are even an inch lower:cool:.
    Starship16 and Grit like this.
  4. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Never scraped the underbody yet, in fact be better if it was lower.
  5. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    You must have some high terrain you roll over. Mine is lowered and I dont scrape the under body at all. Bump the front lip I added from time to time but not the under body.
    Starship16 likes this.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I would contact the municipality that the problem is located in and let them know that your prius with 5.9” of Clearance is getting damaged, chances are they will make the curb less dangerous vs possible legal ramifications.
    I would avoid the curb location in the meantime.
    nudriver likes this.
  7. Tideland Prius
    16,445
    The Gen 3 Prius is only slightly below average for ground clearance for compact cars so other compact cars must be scraping too. (average is about 5.5" I believe)
    Also, why are you driving over curbs? Unless you're talking about a speed bump? If so, there's a flaw in the speed bump design.
    The problem is that the Gen 4/Prime is/are lower :( (4.8")
    The Gen 3 has a 5.1" ground clearance, not 5.9".
    Starship16 and jerrymildred like this.
  8. frodoz737
    frodoz737 Top Wrench
    4,531
    2,437
    33
    Here ya go...
    Tideland Prius likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    I agree that the Prius is not particularly low. In fact, lots of people lower them, although I think that's unwise.
    There are lots of poorly executed driveways and speed bumps around here, too and even if you don't bottom out on them, you don't dare take them at the posted speed limit. That's a road engineering defect, not a car defect. We should not need off-road ground clearance if we're not going off-road.
    #9 jerrymildred, Aug 11, 2018
    Tande and Starship16 like this.
  10. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Side Rant.
    I know my relevancy to youth is rapidly fading.
    But I think most new cars/sedan/hatchbacks...are too low from the factory.
    My Honda Fit is low to the ground. I'd like more height and clearance. But the astonishing thing to me, is especially with the younger set, lowering the vehicle even MORE is something they like to do.
    There are countless cooperative posts at the Honda Fit site, about modifying the Fit to be even lower to the ground. There are aftermarket suspension kits sold to specifically do this very thing.
    I suppose it's mostly just harmless, except for when you hear that scraping sound. BUT...I admit I don't get it. If anything today? I wish vehicles were coming from the factory a little bit higher, I certainly do not want to lower them.
    jerrymildred and Starship16 like this.
  11. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    They should standardize curb height at no more than 4", but I know that's never gonna happen...
  12. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    No worries, mate. They make a Prius for everyone. :)
    RMB, bisco, jerrymildred and 4 others like this.
  13. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    Nice pic;).
    Is that why your road noise is so bad with your tires:whistle:?
  14. Starship16
    1,348
    1,455
    Beach Christmas
    The parking "blocks." Those are the danger. I always try to avoid a space that has parking blocks. The front fascia might scrape on some, or mash right into it. And I keep scraping the fascia on certain driveways, even at an angle just crawling.
    I bottomed out the underbody of the car just once. A hidden dip between two sets of railroad tracks. SLAM! BAM! I was only doing 30 mph. I'm afraid to look under the car. :eek:
    The front doesn't look too low in this photo. But beware.
    #14 Starship16, Aug 11, 2018
    Raytheeagle and Tideland Prius like this.
  15. Tideland Prius
    16,445
    The last gen Camry's ground clearance was 5.9". The current generation (2018+) is 5.7".
    2018 Avalon: 5.5"
    2018 Corolla: 6.7"
    2018 Corolla iM: 5.5"
    2018 Yaris/Yaris iA: 5.5"
    2018 Prius c: 5.5"
    2018 RAV4 Hybrid (except SE): 7.0"
    2018 RAV4 Hybrid SE: 7.4"
    2018 RAV4: 6.1"
    2018 RAV4 Adventure: 6.5"
  16. frodoz737
    4,531
    2,437
    33
    On the lighter side...for those really deep curb cutouts.
  17. nudriver
    nudriver Member
    247
    28
    los angeles
    Thanks for all the feedback boys. All I can say is that I have never had a car that bumped and scraped the underside of the front and bottom as much as my 2012. I assume that's a Gen 3.
  18. Starship16
    1,348
    1,455
    Beach Christmas
    You are NOT alone out there... :ROFLMAO:
