Bottom part of hatchback window tint?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by kalome, Oct 24, 2011.
  1. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I don't know about other Prius drivers but at night I am annoyed by car headlights behind me when they get close, especially when they get the right distance at a stop light and their headlights shine in through the back vertical hatchback window.
    It is very bright.
    When I had my window tint done, the guy there told me that it is plastic and they do not tint plastic.
    It bothered me a lot when I first got my Prius but after having my car for 3 months I am getting a little use to it. Maybe this doesn't bother too many people but if it does...anybody out there have a solution for that piece of the back window since it is so bright when headlights shine in?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    People have tinted that window. The lights don't bother me but I have the autodimming mirror and that helps alot. You could also look into getting an aftermarket autodimming rearview mirror. People have done that on here as well, there may even be a thread describing the install etc. (same goes for the tinting that rear small window)
  3. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Okay, thank you and sorry about posting in the wrong section.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    No problem about the forum, that's one reason I'm around here lol.
    I'd look for the threads to help you in the tinting and mirror but I have to run so I'm pressed for time right now. If you can't find anything just let me know and I'll post em' up later. :)
  5. macmaster05
    macmaster05 Senor Member
    4,050
    728
    Every once in a while you should post in the wrong section on purpose. It's job security for Mark and keeps him busy. ;)
    If you tint the lower hatch window just be sure to go lighter than usual since it already has a purple-ish tint to it. I've found that the barrier between the main hatch window and that lower section blocks tailgater's headlights perfectly, so me, it's a waste of $30 to tint that lower window.
  6. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I tinted mine. You have to get a lighter tint on top of it, to match other windows, since that window is already factory tinted.
  8. andino
    andino Senior Member
    746
    550
    San Jose, CA
    I tinted mine. I used a 40% tint coupled with 15% on the rest of my windows to give it an even look from the inside looking out
  9. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Thanks for all the replies.
    Macmaster - Most of the time that barrier between does fit perfectly but every once in a while a driver will keep back a little bit further than normal and it will align with the back window.
    rrxing - thanks for the screenshot, good info.
