Bought 178k miles used Prius, what maintenance should I do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Us3dPriusOwner, Aug 24, 2022.
  1. Us3dPriusOwner
    Us3dPriusOwner New Member
    United States
    I just bought a used 2007 Gen2 Prius with 178k miles and 1 owner. Cleaned out the AC blower motor fan and the Battery cooling fan myself. Both had tons of dust accumulated.
    It shows on the CarMax report that previous owner kept regular oil changes from dealership every 5000 miles.
    when I went to Toyota dealer to get a pre-purchase inspection they said leaked muffler and 12V battery cable is not the correct one (it’s not grounded correctly), and said they don’t know if any flushes have been done with fluids.
    I’m thinking take care of the battery cable since that’s minor but I don’t know the part or where to get one so I can install it myself.
    leaked muffler is an issue, but not sure if I can get it repaired or just get it replaced?
    what should I do with the Fluids? Get them all flushed?
    already changed engine filter and cabin filter.
    hybrid battery seems to be working fine.
    51,689
    welcome!
    everything! :p
    go to toyota.com/owners and sign up. any dealer maintenance and recalls will be there.
    the schedule is there as well, and you can compare what's done to what is recommended.
    consider changing the tranny fluid, which toyota calls 'lifetime'
    Us3dPriusOwner likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,540
    5,081
    Pacific Northwest, USA
    Can you share a picture of the battery cable issue... Just because it's not the one Toyota uses, doesn't mean it's not working properly... As for fluids, I wouldn't worry to much about that yet, but changing the transmission fluid at least once is wise.
    As for hybrid battery pack, get yourself one of these OBD2 readers: https://www.ebay.com/itm/265484403768 and use Dr. Prius app to monitor voltage difference between the 14 blocks of the battery pack. As that difference gets worse you'll need to do some maintenance or repair. Saving up for a Project Lithium upgrade battery pack in a year or two would be the best way to improve overall vehicle performance.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,529
    754
    Southern California
    Buy some pH test strips which work in the 5-10 range and verify that the coolant in both loops is still basic, 8 or higher. If not, change the coolant in that loop. (Chemically it isn't acidic, and so a problem, until the pH is below 7, but if it is less than 8 it is wearing out and should be replaced.) Note, take out a drop using a clean rod or straw and apply to the strip. Don't dip the strip into the coolant tank because most strips will leech one chemical or another into that fluid. Bad for the car? Who knows? Don't do it. Coolant test strips available at auto supply stores might be calibrated to read in something other than straight pH, for instance, they might read 1 to 5, where less than 3 is "replace".
    Check the oil level and color. These cars tend to burn oil if they have that many miles. Check often at first, just in case yours burns a lot.
    Check the engine and cabin air filters, and replace if dirty. Wait, you already did that. Never mind.
    Check the dates, tread depth, and general state of the tires. Replace if needed. Rotate if needed.
    Check that the brake fluid level is OK. Have the brake fluid tested when the car goes in for service. Or buy some strips and do that yourself.
    Check the voltage on the 12V battery. (Search in this forum, there is a way to do it using the MFD.) If the battery reads too low replace it.
    Test the windshield wipers and replace if needed. (I now test wipers on rentals before leaving the lot - much better than finding out they don't work well the first time they are needed.)
    Get a compatible OBD2 reader and a copy of Dr. Prius, or the right cable and Toyota's Techstream software, and check the voltages on the traction battery. Best to find out now if it has some weak modules.
  5. nancytheprius
    nancytheprius Active Member
    365
    156
    iowa
    replace the transaxle fluid, pcv valve, and both coolants. get the parts and fluids from your local toyota dealership parts department
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,030
    1,959
    NJ-USA
    Hello & welcome to PriusChat.
    Things to consider doing on a Gen2 Prius (sooner rather than later):
    Change all the fluids - including the transmission. Replace spark plugs and PCV valve. (Don't be surprised if you need to replace the ignition coils at some point). Clean the throttle body bore and MAF sensor.
    Check the oil and coolant levels every week until you know how stable they are (& if the engine uses oil).
    Might be a good idea to get some type of shield for the catalytic converter (slow down any cat thieves by a minute or so).
    Consider replacing the inverter coolant pump (with a genuine Toyota part). Inspect (and replace as needed) the engine water pump drive belt and tensioner pulley. Inspect the water pump , hoses, and radiator for leaks.
    Inspect the underbody brake and fuel lines for rust.
    By the time the inlet pipe on the muffler begins to leak, the muffler body is probably on its last legs. I cut out and welded in a section to repair the pipe on mine, and a few months later the seam on the muffler blew out. Got a new OE stainless assembly- that'll outlast the car. Most parts store replacement mufflers will rust out in 2-3 years.
    If your appraisal indicated that the tires, brakes and suspension were ok, then drive the car and see how things function.
    You might want to read my scantool app review thread (stickied at the top of the Gen2 Technical Discussion forum) - having a capable scantool for your Prius might be a good idea.
  7. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    If it hasn’t been done in past 60k miles, change the serpentine belt. Can’t often see the wear until you remove it to check it and at that point, just change it.
  8. Us3dPriusOwner
    United States
    So sorry for the late replay on this one. Had to move residences and used the 07 Prius in the move and it seemed to be working fine, just needs some maintenance done and possibly a new 12v battery. The engine kicks in quickly when car goes above 9 mph, the HV battery charges quickly and discharges quickly so that tells me some modules might be on their way out.
    Here is the picture the technician at the Toyota Dealership took and showed to me, he said the battery back cable was not grounded properly with the car.
  9. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Strap on battery post is missing a bolt, while in there take off the end bolted to the chassis and make sure all metal to metal areas are shiny.
  10. dolj
    dolj Senior Member
    8,386
    4,271
    Wellington, New Zealand
    While that bolt is missing this will always be an unsatisfactory and unreliable connection.
  11. Mendel Leisk
    41,126
    Maybe the tech took the pic while work in progress? I can’t imagine them not noticing bolt missing from cable clamp at post.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    That's the original ground cable that comes with the car. Looks like the car lot replaced the battery since it probably sat on the lot for a while and forgot to install the bolt and nut. Also looks like the post is shorter on that battery. Show us a full photo of the battery. It may be a weird battery.
    But all you need to do is buy a nut and bolt and install it. Cable looks ok.
    Here's mine you can see it matches yours so the dealer is full of dookey that's the factory chassis cable.
    A G2 with that mileage & dealer maintained will eat alot of oil. Its important you check it every few days before starting the car to see how bad the oil use is. If its low top it off.
    I would also move up to a 40 weight oil too like Mobil 1 0-40. Five quart jug at Walmart for $26. It will help with the oil loss.
  13. fotomoto
    fotomoto Senior Member
    5,632
    3,809
    So. Texas
    For reliability, first thing I'd do before dumping a ton of money into it on the basics is check the HV battery for origin/health/age and determine what a NEW, not used/rebuilt, replacement battery will cost.
    I'd check the bottom of the battery tray for the missing bolt/nut first. BTDT :D
    edthefox5 likes this.
