Bought a 2007 with 204,000 miles with a bad battery, what to do now?
Discussion in 'Gen 2 Prius Technical Discussion' started by PheonixPrius, Jul 12, 2018.
  1. PheonixPrius
    PheonixPrius New Member
    Midwest
    Hello everyone!
    I bought this 2007 Prius with 204,000 miles on it, sight unseen from the salvage auto auction Copart for $1800, no damage, runs and drives, donated vehicle, I thought how could I go wrong.
    Now I realize that there are many ways this could have gone wrong and it was quite foolish of me...
    To begin, Coparts buyers fee was outrageous (very stupid of me not to check this beforehand), with all the other fees they tacked on, I was down $2350 all said and done.
    When I went to pick it up the 12V battery was completely dead. After a jump it started right up and I was on my way. It drove fine on its way to the interstate, no lack of acceleration or anything, then the big red triangle and all the other lights came on. Still I merged onto the interstate and it drove without a problem to my destination 20 mins later with a trip avg of 49mpg.
    I bought a new 12V battery for $180 installed it and checked the codes, P0A80 and P3023, replace hybrid battery pack and battery block 13 becomes weak, darn.
    I decided to take out the HV battery fan and clean it while I had the interior apart to replace the 12V, it looked good, just a bit dusty.
    The internal combustion engine felt smooth on its maiden voyage, and I had no problem cruising at 75mph up and down the somewhat hilly interstate. Well, after cleaning the battery fan, I did an oil change...
    Half a liter of black, black oil came out. Half a liter...
    It's full of fresh 5w-30 now, but this makes me wary of how this vehicle has been maintained.
    I have only driven this Prius for two days since then, I have seen the battery indicator go from one bar, up to almost full, sans one green bar, back down to one bar in the matter of minutes.
    The acceleration from stops is abysmal, the battery needs to be replaced, I've accepted this.
    However, yesterday I am accelerating up the on ramp to the interstate, I get up to 60mph and the internal combustion engine rev's high, really high, and stays there, I take my foot off the accelerator, and the vehicle slowly accelerates. I know what your thinking, but it's not the floor mats, they are not installed. So I take the next exit, shutdown and read the codes, P0A80, P3023, and P3024. Another one bites the dust.
    After looking around I cannot figure out what caused the racing engine. I put it in drive and take off, after about 40 more highway miles on 3 different trips, this has not happened since.
    So I am now trying to decide how not to lose too much money on this ordeal, is this racing engine a sign of a larger problem? Or is it just a byproduct of the bad HV battery? Should I invest money in a new/reconditioned/salvaged battery? Should I look into options on how to recoup some of the money I spent on this vehicle? What is the meaning of life?
    There is a HV Battery on my local Craigslist right now. It is from a hail damaged/front end damaged 2007 with 113,000 miles on it for $750. The seller says he bought the car to part it out. He checked the voltages on all the cells at 7.5-7.6 volts, and he has had the car apart for six weeks. I asked if he rebuilt/refurbished the battery and he says no, he just took it apart to check the voltages so he could feel comfortable selling it.
    Could this be an option I should feel comfortable pursuing, knowing the money I have already put into this?
    I would be installing the battery myself. I am no stranger to turning a wrench, but I admittedly know very little about electricity.
    I have been reading up on how to rebuild the battery on this site and have been feeling overwhelmed, even though that's the option I would really like to pursue, it seems a little too time consuming to me at the moment.
    How do you think I should carry on? Is that $750 battery worth the risk?
    Thank you for your thoughts in advance!
    P.S. I have a blue tooth OBDII reader, how do you clear the codes while the engine is not running? If I hit the start button without a foot on the brake, the main display lights up, but the reader will not connect. If I hit the start button with the foot on the brake the ICE turns over and never turns off, I am afraid of clearing the codes while the motor is running.
  2. JC91006
    16,674
    8,519
    For $750, take the plunge. But it will only be slightly better than what you have, give you probably a year or 2 of service.
    As for your auction car, there may be a bad oil burning issue, which will lead to another engine and catalytic converter in your near future
  3. PheonixPrius
    Midwest
    Thanks for your response. I have been leaning towards the $750 Craigslist option as well. I just wanted to make sure that problem where the motor surged in RPMs on the highway wasn't a common sign of bad things to come.
  4. JC91006
    16,674
    8,519
    I believe that happens when the engine is looking for more power, to compensate for the loss of battery problem
    Fred_H likes this.
  5. ski.dive
    ski.dive Active Member
    959
    241
    Hutchinson Island,FL. Mt. Snow,VT
    Is there an independent HYBRID REPAIR SHOP near you?
  6. PheonixPrius
    Midwest
    That's what I thought too, thank you
    There aren't any shops near me that specialize in Hybrids, which is surprising to me. There are quite a few that list hybrids as something that they do work on though
  7. Chodronish
    Chodronish Member
    171
    40
    Illinois
    Four Touring
    Could the engine revving be trying to charge the HV battery? I am thinking I read something about that in another thread.
  8. PheonixPrius
    Midwest
    I want to thank everyone for their replies. Shortly after my last post I decided to buy the $750 craigslist battery. Installing it was quite a bit easier than I thought. Everything went well and now the car drives normally without any warnings or check engine lights!
    With that said, I am still a bit leery on its performance. I have since driven 275 miles in the past month with about 35/65 city/highway driving, and I have averaged 48 mpg, which is great!
    However, here are my two concerns:
    1) When coming to a stop in the city, the ICE turns off, which from what I know is expected, but it seems to run really rough and shake the car in the final second before it dies, is this a common malfunction with a fix?
    2) From what I have been reading, the battery/electric motor should be capable of bringing the vehicle to speed without the ICE within the city. From my experience the ICE kicks on with every acceleration from stop. Even with absurdly slow acceleration and green bars, it will kick on around 5 mph. What could be the cause of this?
    Thank you!
  9. VFerdman
    VFerdman Senior Member
    1,185
    1,212
    Western Massachusetts
    Rough ICE turn off is not normal on a warmed up engine. But the rest of your experiences are indicative of fairly normal operation. ICE will kick on while accelerating, but will shut itself off if you are "gliding" under 42mph. You can see that on the energy display or on one of the many apps that talk to your OBDII dongle (Hybrid Assistant is great for that).
    I think you are probably okay for some time, but the fact that there was practically no oil in the ICE when you first got the car is of concern. Keep an eye on the oil level and keep it up. Your fuel economy is just about perfect, so enjoy it while it lasts. You may want to think about buying a Prolong system to condition the battery to try and get more service from it. It's a pricey system, but if it gets you another 2 or 3 years, then it's worth it. I would only do that if I was sure ICE is in good shape, though.
    Good luck and welcome to PC!
  10. terramir
    terramir Member
    318
    50
    Los Angeles
    The Prius is sometimes rough on stop throttle body and other decarbon service helps ( some peeps help me here chime in) as for the oil if you can do this buy full synthetic and use 3 5/30 and one 10/30 or 10/40 of the same brand a little thicker oil helps; however, the real fix is replacing the Piston rings and the valve insets. From what I have read about this engine and it's non hybrid brother the fix is the same.
    Actually I was about to post a thread about this asking how involved the cost is on this or can this even be done diy.
    terramir
  11. terramir
    terramir Member
    318
    50
    Los Angeles
    BTW my battery is slowly dying as well and we'll at the current time it sometimes revs to max especially with the AC on and when I have to step on it. high revs is really a good indicator for a dying HV Battery.
    terramir
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Depending on the severity, it's normal when the engine is in its early warmup stages. Here's a description of the Gen 2 warm up stages. Note stage 3 in particular.
    http://drivesmartwi.com/uploads/DSW_Toyota_Prius_Initial_Stages_of_Warm-Up_Wayne_Revised_2_.pdf
