Bought a 2019 Prius LE w/ 190k miles!!
Discussion in 'Gen 4 Prius Main Forum' started by Willl, Jan 11, 2021.
  1. Willl
    Willl Junior Member
    34
    Orlando
    Just bought a 2019 Prius LE w/ 190k miles (crazy), had some codes that I cleared, everything seems to be running and driving fine on it...
    What things should I get done on it or be checking, preventative maintenance, oil change, etc..?
    amos, SFO, Mambo Dave and 1 other person like this.
  2. telmo744
    telmo744 HSD fanatic
    2,178
    768
    Portugal
    The transaxle would benefit from changing transmission oil, IMHO.
    douglasjre, SFO and mikey_t like this.
    49,401
    congrats!
    start by plugging the vin into toyota.com/owners to see what they have for service history
    all the best!(y)
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Wow congratulations! How is that high of miles possibly?!?
    check the hybrid battery air filter under the back seat ASAP!
    At 200k it would be a good idea to clean the egr system+egr cooler.
    amos and SFO like this.
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
  6. Willl
    Willl Junior Member
    34
    Orlando
    I already looked up Toyota dealer service history online, no history unfortunately, so it was likely fleet maintained
    It looks like it was maybe a chase car for semi trucks. Which would likely mean mostly all highway miles
    #6 Willl, Jan 12, 2021
    mikey_t likes this.
  7. Mambo Dave
    Mambo Dave Active Member
    640
    306
    2019 Prius
    L Eco
    Did it have a frontal hitch on it?
    I mean, jeez, I know there are some chase vehicles out there, but for them to do that many miles in that short of time... I don't get what they would be doing. Chase vehicles for wide loads don't normally rack up huge miles with those slower speeds.
  8. MichelleStone
    MichelleStone Senior Member
    549
    817
    Mariposa, CA
    How much did you pay for it?
  9. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    I would change out all of the fluids and change oil to start. I would consider using the BG trio of EPR, MOA, and 44K before the oil change as well.
    Purely for data it'd be great if you could take a look at the EGR system to see if there is any build-up, but I totally understand not wanting to take that on.
    amos and Willl like this.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,200
    5,897
    Columbia, SC
    I'm curious as to what codes it had before you cleared them..............those could be a good indicator of items that may need checking
  11. Willl
    Willl Junior Member
    34
    Orlando
    Didn't have a front hitch, but did have front and rear strobes installed on the windshield and rear hatch
  12. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    Thats a crap ton of miles, with it mostly being highway driven it should last many more. Age and Mileage dig into it equally. Being that its basically a two year old car, it should go much further without too much issues. I would say a transaxle flush would be a good to do maintenance item and maybe a flush of the fuel system and injectors maybe.
    Willl and mikey_t like this.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Also, remember that a percentage (30, 20, 40?) of the driving probably didn't have the ICE running. You can check the lifetime EV% - trip meter to ODO. On the MFD:
  14. Willl
    Willl Junior Member
    34
    Orlando
    Just got the car from auction, cleared existing codes to see if any would come back, car felt like it was driving fine for the first few short trips.
    I had the temp sensor flash and then go away several times, finally it triggered a CEL code. Code was for coolant sensor, I checked the coolant level and it was completely empty and the coolant cap was barely on. I added coolant and CEL went away, but same thing happened again, pulled over to check and coolant was empty again. I did this several times having to fill the coolant reservoir until finally it stabilized and didn't go down again. No sign of coolant leaking on the ground anywhere....
    I checked on Toyota Owners History and saw there was a previous diagnostic done at the dealership in November, but there were no notes that told me what happened. After calling the dealership several times I finally got a response... Unfortunately Toyota dealership diagnostic says needs new engine. Blown head gasket and coolant in 2 of the cylinders.
    Anyone know how much it might be to replace a gen4 motor? The car is a 2019, does it use the same engine as 2016+?
    Is it possible to try to use a head gasket sealer product??? Has anyone had any luck with this before?
  15. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    If your coolant is disappearing, and your oil is clean with no coolant contamination, and no rough starts/misfires, the headgasket probably isn’t blown, and you have a coolant leak.
  16. alanclarkeau
    7,044
    7,584
    "coolant in 2 of the cylinders"
    mikey_t likes this.
  17. Willl
    Willl Junior Member
    34
    Orlando
    When I first drove the car for the first several trips the engine started smooth and drove/ran fine. Then after the temp light came on and found the coolant empty, even after refilling coolant, I started noticing the engine shaking when it would start, and also as I would be driving I would feel the rpms or engine power start going down when I would be holding the throttle at a steady level
  18. robsnyder20
    374
    301
    SW Florida USA
    I see that your in Orlando, maybe give a call to Tampa Hybrids, they would be probably a second or cheaper option to get the car back in working order again. I was wondering why someone who put on 190k miles in a year would sell the car for probably next to nothing instead of putting another 150 or 200k miles on it being that its so young in years. I think you got it figured out :( As far as the fix a engine using a 20 dollar additive it might be a good option if you want to try it but I think sooner than later your gonna have to do a seal or an entire engine on the car once it has a blown head gasket.
    jerrymildred and Aaron Vitolins like this.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Well shoot, this definitely sounds like the tried and true headgasket problem on the 1.8.
    unfortunately this is bad news, as I and many others were hoping Toyota fixed the headgasket issue on the updated 1.8 for the gen4.
    As you asked earlier, a 2016 engine will fit into your 2019 with no issues.
  20. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I agree, Tampa Hybrids is a great business. The owner has been a member on here for years and has a great reputation.
    jerrymildred likes this.
