Bought a cheap with 100k km. Prius 2 with Red triangle means battery problem. Please help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alex Rigo, Dec 15, 2019.
  1. Alex Rigo
    Alex Rigo New Member
    Athens Greece
    Hi mates. New here...
    Well i bought a 2007 prius...
    I knew it have a problem but it has only 100.000 km and the egine is very good.
    Well a little before i take it the batteries showed the triangle. But now the ventilator for the cooling system of the batteries work all the time i drive.
    Well. I also bought the OBDII for chech witch modules need replacement. (i found all them out at internet).
    I tried the Torque app and also one more... Both give me many info from the car. I don't know why but it doesn't inform me about the volts of the modules, non of both apps.
    Anyone kmows whats that means? What i have to do next? Any solution other than to go to Toyota?
  2. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    Sounds like the HV battery is failing.
    Do you have a multimeter, or a volt meter?
    Go online and buy a 'mini-vci' cable, costs about u$20. You can use it with Techstream, same software toyota uses.
    Since the cooling system for the HV battery is running all the time, have you had a chance to at least clean the HV battery fan?
  3. davecook89t
    davecook89t Senior Member
    1,085
    817
    Washington State, Florida
    Four Touring
    If you haven't tried Dr. Prius or Hybrid Assistant, you may want to try them. The version of Torque Pro that I have required a separate download of Prius specific information (called PIDs) in order to get block specific information. See below:
    Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat
    [Edit] @SFO, I now see you have already included that link in your signature.
    SFO likes this.
