Bought a Falcon battery before coming here.... follow my journey
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JerzyBoy973, Sep 5, 2019.
  1. JerzyBoy973
    JerzyBoy973 New Member
    I recently purchased a 2006 Gen 2 with a dead traction battery from a friend of mine. I started looking around locally for a replacement and came across Falcon. I thought, "Great!! These guy are local and they provide a warranty!!" So on 8/22/29 I pulled the trigger, I drove up to their shop with my core in hand and took posession of my replacement Gen 2 battery, built with Gen 3 cells. I was ecstatic, until I removed to cover to find filthy cells and corroded contacts. I wasn't expecting a brand new battery, but I at least expected it to look "touched". The website shows cleaned nickel plated contacts and set a standard that this thing did not come close to meeting. So I called Falcon and they assured me that I had the right battery and they'd stand behind it if anything happened. So I installed it ... on 8/22/2019... and on 9/4/19 my red triangle is on with a P3000 and module #6 showing up as the culprit on my scanner.
    I called Falcon to alert them of the failure and Mark has been responsive thus far. I'll be taking it up there soon to have it swapped out and I'll update this thread with my experience.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Why didn't you go with one of the new options?
    Did you clean the HV battery fan when R+R'ing the battery?
    m.wynn and Raytheeagle like this.
  3. JC91006
    16,674
    8,519
    The image of the product you received is absolutely horrendous. You see all kinds of leaks on the bottom battery case. If you can get a refund, that's what you should be doing.....before you regret it some more and refund period is over.
    No professional refurbished product should look like that, and it lasting a week shows what you'll be up against if you don't get your money back and move on to a more respectable rebuilder or NEW battery
    m.wynn, Raytheeagle and SFO like this.
  4. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    You paid almost 1200 bucks and It didn’t even last 2 weeks? Hope you paid with something you can cancel
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    This is awesome...I laughed so hard I may actually puke.
    Not at the OP, just about the battery...
    Please post some of the serial numbers from the tops of the modules. We can decipher that for an actual manufacture date. Are they actually Gen 3?
    m.wynn, dubit, Raytheeagle and 2 others like this.
  6. bisco
    51,155
    if they don't give you your money back, call your cc company, the attorney general and yelp reviews.
    and even if they do, the ag's office should be made aware of their scam
    see the longstanding thread here on falcon ripoff
    m.wynn likes this.
  7. JerzyBoy973
    The idea of having Gen iii cells appealed to me :(
    I checked the fan and it was squeaky clean.
    Yeah, I'll have to go this route if I can't get it resolved.
    I'll post em when I pull the batt this weekend (y)
    facts
    #7 JerzyBoy973, Sep 6, 2019
  8. Tideland Prius
    16,445
    Please use the multi-quote function.
    Skibob and SFO like this.
  9. JerzyBoy973
    Update:
    So I got the battery up to Mark at Falcon. After looking it over the problem was almost immediately apparent. The bus bar bolt @ module #6 was loose. He had his guy check all of the bolts with a torque wrench, they double checked everything and sent me on my way. I installed the pack right there in the parking lot and drove home 45 minutes with 0 codes. I did the Dr. Prius app battery test and life expectancy test and everything checks out.
    I saw people saying he doesn't communicate but he always took my calls and didn't give me any grief in getting everything sorted. I'm happy.
    #9 JerzyBoy973, Sep 11, 2019
  10. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    And the corrosion issues? You're ok with that?
    Any serial numbers?
  11. JerzyBoy973
    Didn’t get a chance to get any serial numbers. I pulled the batt right there in the parking lot.
    I’m not super bothered about the corrosion. I’ve already decided to clean that up myself when I strip the interior down to do my rear struts in a week or two. If there’s any leakage or seeping after that point the. I’ll obviously have a bigger issue.
  12. JC91006
    16,674
    8,519
    You seem quite handy with this stuff, you could've just bought the new battery for $1600, install and forget about the battery for the next few years.....
    Skibob and audiodave like this.
  13. JerzyBoy973
    I really do wish I knew about the $1600 batteries. My dealership wants $1900 and they won’t price match. I did inquire before going to get this on rectified yesterday. But Dr. Prius gave this batt a good life expectancy so I’ll keep my fingers crossed lol.
  14. JC91006
    16,674
    8,519
    I'm surprised nobody mentioned it, it's not a bad deal for New aftermarket batteries, and you can sell your old modules on Ebay to recover some costs. It's not the same as original Toyota OEM batteries, but so far it's held up pretty well for members who have bought them.
    The refurbished battery you have will be good until one of the modules fail. So you might just have to keep claiming the warranty until it ends.
    m.wynn, Raytheeagle and Skibob like this.
  15. bisco
    51,155
    i'm glad he's at least communicating, please keep us posted, all the best!
    m.wynn and JerzyBoy973 like this.
  16. Skibob
    2,912
    1,502
    Northern California
    My guess is he didn’t check here before he bought his battery. He bought the battery last month and signed up here this month.
  17. JerzyBoy973
    Yup I signed up after I purchased the battery.
