Bought a Prius last week. Two questions.
Discussion in 'Gen 3 Prius Main Forum' started by clickerman, Apr 30, 2010.
  1. clickerman
    clickerman Junior Member
    33
    chicago
    Bought a Prius last week. Two questions. (I've researched the forum for answers.)
    I just bought a 2010 Prius III and absolutely love it, and have become addicted to looking at the readouts to make sure I am out of the ECO zone as little as possible.
    A couple questions:
    1. I notice that when using the B gear the battery charge indicator jumps way up. When driving in a suburban area with lots of stops and starts is it advisable to use the B gear whenever possible to delay using the breaks. This would theoretically keep the battery at a better charge state and decrease wear on the breaks. Does it cause any undue stress on the transmission or engine? I realize people on this forum state that the B gear should only be used for long downhills, but I do notice an uptick in the battery charge when B is engaged.
    2. How do you generally use the Trip 1 and Trip 2 readouts? Do you reserve one of them for the interval for gas refills?
    Thanks,
    John
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    A) There are conversion losses to converting rotation to electricity and then electricity back to rotation, so never using B or the brakes would be best, but most of us can't plan well enough to never need to slow abruptly. Regeneration is simply the least horrible way to disapate kinetic energy. So saying 'I am getting' lots of regen' is the same as saying 'I am not planning my drive well enough, yet.'
    B) You can't hurt the car with B, it is just less fuel efficiant than not using B. And if you ever really do need B, it will still be there. (There are esoteric times when B is a hypermiler trick between 24 and 7 MPH. B can keep the ICE rotaing if you are decelerating for light you plan will change just before you get there, but you risk nailing someone who is running their red)
  3. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    Re: Bought a Prius last week. Two questions. (I've researched the forum for answers.)
    As for your second question, there are likely as many answers for that as there are drivers.. I tend to use "Trip A" to record each fill-up, and reset it each time... B I use for longer trips, and whenever I would like to measure something specific.
  4. draheim
    draheim Member
    124
    Seattle
    2018 Prius Prime
    Hi John, I have had my Prius for about a month now and this forum has been invaluable in learning about the car. Lots of experienced Prius owners here who can answer just about any question you come up with.
    I use Trip A to track my current tankful (still only on my second tank) and Trip B to track cumulative lifetime stats. The reason I selected A for current and B for lifetime was by accident; I inadvertently reset Tank A (by holding a certain button for too long) halfway through my first tank.
  5. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    Search the site for more about engine braking. What the B position does is to use excess motor-generator output to spin the engine while not feeding gas to the engine. this is in lieu of using the motor-generator output to charge the traction battery. Bottom line is, for optimum mileage, you don't want to use B very much. Dragging the brakes is fine, because you're not dragging the brakes unless you're really pushing hard on the pedal; mostly, you're sending coulombs into the battery.
    For the rationale, do the search. It's been explained here eloquently.
  6. Pooka
    Pooka TIFOSO
    86
    KANSAS CITY
    2014 Prius Plug-in
    This. I will never reset 'Trip B'. plus told my bookkeeper to track all prius gas receipts in Quickbooks seperately ...
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    B gear wastes energy by spinning the ICE as a pump. Yes you see an increase in regeneration, but you would see the same increase if you press the brake pedal, without wasting energy in engine braking.
    Use B gear on BIG hills. Otherwise forget about it.
    Tom
  8. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    I know you are excited. Congrats and welcome.
    Just drive normally. B are used for engine braking when going down hill. Although it will not harm your transmission I think you just need to drive normally in the normal drive gear.
  9. dtuite
    dtuite Silverback
    182
    31
    Redwood City, CA
    LESS regeneration going to the battery with B than with D. If I understand the other posts.
  10. Tideland Prius
    16,610
    1. Lightly pressing your brakes (or just coast) will regenerate too. Using B will decrease efficiency because the engine also spins to provide engine braking whereas simply coasting or using your brake pedal will keep the engine off.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Here is some good information by Hobbit, one of our more knowledgeable Prius drivers: HSI
    As others have said, only use B mode if you are descending a long steep hill with a fully charged battery, it really isn't good for much. I have noticed I can regenerate over twice as many Amps by proper use of the brake pedal in D than B mode does.
    I enjoy having two trip indicators, if I'm on a long trip I set one for the entire trip and reset the other one each morning before I start out.
  12. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i wouldn't worry about brake wear... in my gen II i didn't have to change the front brakes till 128,000 miles..... if you are in a high traffic area, such as Los angeles, using B is more comfortable in traffic since the brakes seem to have a delay.. the only problem with using B in this situation is that you slow down much faster and cars behind you are sometimes not aware... making you a road hazard...
  13. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I don't understand why you are so eager to charge the battery by using the B so often when the battery still holds sufficient charges. If the battery charge drops to 30% or lower (or whatever the factory programmed level it is), the ICE will kick in to recharge it. What's the advantage to keep your battery charging state in 90%, 100% of the time??? Safety is the key. Drive it normally as you would and enjoy the ride.
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    1) B is not recommended because it causes u to lose to much momentum. if u need to lose that much, u r driving too fast for conditions. B mode should only be used on extreme hills or very slippery conditions. regen is a lose situation. the amount of power regained is no where near the amount of power expended to attain set speed.
    2) Trip A is for the tank mileage, Trip B i use for daily resets (on the 2006, trip B is my "oil counter" since it does not have a maintenance log. of course, i guess i could just manually write it into the maintenance log provided but have not up to this point, but probably should.
    i get all oil changes at the dealer but i only have to log into their website and check the mileage on the cars when the oil was changed last... so i guess i am lazy in that respect
  15. RoJo
    RoJo New Member
    Philadelphia
    I have been using Trip 2 for gas intervals. I do a lot of highway driving and have been recording mpg's at 50. I don't know about the B gear.
