Bought salvage 2005 Prius with 35,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by Wingding, Jan 27, 2011.
  1. Wingding
    Wingding Junior Member
    Montana/Michigan/Pennsylvania
    Well, I already have had the Honda civic hybrid 2005 for a number of years but always wanted to have a go at the Toyota Prius too...
    The difference here is I bought a salvage Prius and will have to figure it all out.... I think Im at the right place.
    The car has been sitting for a couple years so Im hoping the main battery will still be OK.If you do not charge these batteries up for a couple years ..... are they Toast?
    Anyway ..to get started, I need a new aux. Battery and will send for the Optima D51 after reading some threads the past week.
    Also was a great thread on how to open the key fob and replace the {2032} batteries...
    Im only getting started.... The car appeared to take a pop to the front end ... It was more of a "tuck job" as the hood appeared to be compressed slightly as if the car skidded and the wedged under a guard rail.. Lights broke both sides...
    But the engine and radiator appear to be all right...
    I know this is going to be a challenge... but what the heck... That's half the fun!
    Anyway, Im sure I'll be knee deep in problems after the battery comes in and we attempt to "power up" and see what else is wrong.
    I'll be looking for help for sure! I think Im at the right place though!
    Greeting's to all!
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Welcome and good luck on the project. I would look into (thread search) internal battery corrosion issues on the metals that connect the individual cells. That can lead to reduced performance or early failure. I would think sitting unused would promote this.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Other things to check are the coolant storage thermos on the driver's side of the engine compartment, as this is frequently damaged in a front end collision.
    There are ways to charge the HV battery without visiting a Toyota dealer, but you have to know what you are doing. High voltage safety is paramount! Look for terminal voltage > 200V and module voltages > 7V. If you don't have that, then add 1 amp-hour of charge, or buy a salvage traction battery, and PM me if you want to sell the old one. Frequently cycling under heat is the primary source of fatigue, rather than sitting for a long time. There is a lot of good information available online for charging/reconditioning traction batteries. This is a good project to prepare you for reconditioning the pos hv battery in your HCH too.
    You may also benefit by having a decent scantool. AutoEnginuity + Toyota is a good option but there are others.
  4. josa
    josa New Member
    cincinnati
    :)best of luck sounds like an interesting journey/ let me know when it's up ad running I would like to know your view on the differences between cars
    josacompa
  5. freidawg
    freidawg Prius Recycler
    111
    35
    Denver, CO
    2003 Prius
    I have rebuilt/resurrected quite a few Prius cars (1st gens and 2nd gens) including front end collision victims.
    Here's a few things I have encountered that might help:
    0) Unless you luck out and it fires right up with no codes (unlikely) you will need a good way to scan and read the DTC's. Search the forums, much good work has been done in this area. I use Toyota Techstream and I don't have hands on experience with the others recommended by members here. I do know that the generic OBD2 scanners (even some real expensive ones) don't do much good. You have to be able to read all of the codes and the sub codes to do much in the way of diagnosis. Might as well acquire this capability up front.
    1) The main battery on the 2nd gen seems to have a pretty long shelf life. That said, if the car doesn't fire up right away, try to verify as much as you can between test starts. Unlike your Honda, the Prius has no separate starter motor. When you attempt to start the Prius, you are using the big battery to turn the electric motor in the transaxle. Repeated attempts to start a car that wont run, using an HV battery that may be at a low state of charge from sitting can deplete the battery. This causes a real hassle, because you have to get the SOC on the battery up to get the car going, You can do this without a running car, but that's a whole different kettle of fish . (This is a very common occurrence on a salvage1st gen car that has been sitting.)
    2) You can use almost any 12v battery to power the car up. I have a lawn mower battery that I bought for $20 at Walmart and some 9" long "jumper cables" that I made from 10 ga wire and radio shack alligator clips that I use for trouble shooting. I can charge it on any ol' battery charger and it's light and easy to carry around. I am not recommending it as the battery to use in the car to drive around a bunch, but as a garage tool, to get 12V onto the car easily.
    3) Do a thorough visual inspection under the hood before you start trying to get it to "Ready ON". Disconnect 12v battery, Pull the service plug and look at everything that may have been touched by the accident.
    4) Here are a few things I found, not a comprehensive list, but things I have wasted time on and I now look for first:
    - Cracks in intake manifold
    - Cracks in inverter case (especially, where the mounting bracket on the drivers side bolts on)
    - Integrity of all connectors, but especially the ones on the Inverter and Transaxle. Look REAL close to make sure they are not cracked. I always disconnect each connector and look at both mating sides with a bright flashlight. The orange connectors are high voltage and you definitely don't want water intrusion from a crack.
    - Make sure all the coolant hoses are good. The ones that go to the transaxle and inverter are easily damaged.
    Best of luck, It may be far less work than you think.
    PM me if you like, I am happy to help if I can
    Eric
    Adopt A Part
    2 people like this.
  6. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    This kind of thread is really interesting to me. I hope the OP keeps us up to date with pictures and such.
    A quick question about the traction battery. If it was too low to start the ICE due to long term storage (and not due to damage), would it be possible to give it a little boost by hooking it up in parallel to the traction battery of a running Prius using ordinary jumper cables?
  7. jdenenberg
    jdenenberg EE Professor
    3,852
    1,847
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Don't!
    • You need to control the current to protect both batteries. Just connecting a full HV battery to a depleted one will incur a high current that will damage both batteries. Keep the charging current below 2 amps to avoid over heating.
    • Jumper cables are made for high current (not needed) and don't have good enough insulation for 200+ volts.
    JeffD
  8. caffeinekid
    caffeinekid Duct Tape Extraordinaire
    334
    44
    Houston
    :welcome:
    If you don't mind the asking- what did you pay for the car and what options does it have?
  9. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Ways to charge a depleted traction battery:
    Use someone's PHEV kit to charge it. Charging time: minutes.
    Current limited HV charger, such as an old lab supply, or build your own by daisy-chaining Meanwell 48V power supplies. Charging time: 1-2 hours.
    Remove the cover from the case (but don't dismantle the pack!!!) and charge individual modules. With acute attention to detail, you can use a 48V nimh charger (actually 56V) and partially charge groups of 7 modules in series. Doing the group where the service plug connects is best handled by using a bus bar from another module pair to jumper the gap. Tenergy sells a 56V 1A charger with dV/dt sensing for $27. For best results, have it on a 2 hour timer so that the string does not become imbalanced. Charging time: 1 day.
    Use a 7.2V charger and charge individual modules. This takes days.
  10. pEEf
    pEEf Engineer - EV nut
    720
    577
    Berkeley, CA
    FYI: you can charge the pack at constant current of 200ma or less without any problems indefinitely. (as long as the pack is in a relatively cool area, and it's in the factory tray with all mounts secure.)
    I made a "quick and dirty" (aka "bad boy") charger out of a bridge rectifier, 2 electrolytic capacitors, and a light-bulb in series as a current limiter. You have to be careful and use common sense, but it's not difficult. The rectifier and caps came out of an old PC power supply. Just your basic voltage doubler circuit.
  11. Wingding
    CAR STARTS UP!!!!
    Upon delivery of the scan tool I was a bit bummed to get no data codes....
    But I attempted to start the car and low and behold she started up!!!??
    The only thing i did was put a well charged battery in.Well I had my first bit of good fortune.
    I want to thank everyone for all the helpful input. I has been sincerely appreciated.
    To answer some questions, the car cost $5400 {2 1/2 years ago when I purchased it}
    According to my recently purchased Toyota Prius by Bentley- It appears I have a #6 or maybe #7 from what I can figure. Not sure about the navigation as I only ran the cat for a very brief period, enough to go backwards and forward about 10 feet.
    That is very good news it seems, ...AH... But one of the bad things is...... I got those HID lights... and AH..... I need another set... and I am finding it not exactly easy to find... A prius in a Salvage yard is pretty RARE!
    For the needs now... I will need to reconstruct the bumper. Im going to need most the components outside the first aluminum support bar. I am going to need another air filter box{which contains the air filter} as the neck of the container has snapped up near the top by the box. I need both dreaded HID headlight assemblies. The radiator can be replaced but I just learned it might not leak at all... Seems the neck where the upper radiator hose goes got bent around enough to make the anti freeze trickle out... Once I had the radiator unit out I carefully took most the kink out without causing any damage.
    IN the long run I'll replace it but for now Im going to put it back in and see if it holds. It appeared to be only leaking out of the top neck because of the twist.
    Im thinking that might be the only thing from allowing me to charge it up and at least go over everything else. The air breather unit is also something to deal with before a real first warm up.I have it epoxied up and drying.. It's just a temporary till I can locate one which probably is not going to be to easy.
    I'll go out and take a few photo's of the car now as someone was asking... It's not gonna look to awful pretty right now cause it's pretty much disassembled and Im in search of parts and i did not clean it from the big 1400 mile tow ...so it's pretty filthy ...but if you look through the dirt....maybe you will see what {I thought} I seen.... and it's looking pretty darn good with it running now ...or at least starting and idling ...
    Off for some photo's....
  12. Wingding
    OK,.... now dont laugh to hard... and remember I got her stripped down so see's looking a little weak..But it at least will now start - idle and move either < >
    So we are off to a good start!
  13. olerox
    olerox Junior Member
    65
    Oregon
    Wow Wingding! Congratualtions on such a promising "start". I bet you felt great going the 10 feet forward and back.
    Keep us posted on your progress. I think your little gem will shine up so nice as you breath life back into it.
  14. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    You probably know this, but take special precautions with computers inverter batteries etc before doing any welding. Looks like a project!!! Take pictures as you go so we can watch the evolution.
    On the headlights, I like HIDs, but I'm wondering if you can put in replacement halogens instead, since you need to buy the whole assemblies anyway?
  15. Patrick Wong
    18,200
    6,474
    No laughter, but regarding the third photo I have two questions:
    1. What is going on with the green bucket, are you draining some fluid into it?
    2. What is the story with the MBZ 190 partially hidden in the corner of the garage?
  16. bisco
    49,490
    what is that, a horse stall?
  17. Wingding
    Hi Patrick,
    The green bucket is just full of tools.
    Let me see what else your seeing....
    Oh...Ok ....That is part of red1969 280sl MB. You cannot see, but right behind the prius is also a Green 1969 280SL... the interesting thing about the green one was it was owned by Rockefeller.Not Nelson but brother Winston {governor of Arkansas}
    That is not a barn....although it may appear to look like one!!!
    The building your looking at is my future house... 32 X 52.... You can drive a motorhome right in. Planned and constructed myself.
    Im obviously still in the building stage. Next to go down are the concrete floors and run in electric and water. Eventually complete with vacuum elevator since the ground level to the first floor is 25 feet!
    Lots of snow around so we try and get everything under cover.
    There is a definite building time and a HIBERNATION time around here!
  18. Wingding
    Seilerts,
    Im starting to think that maybe I might have to go that way...
    {Halogen lights} although everyone pretty much think's the HID are superior...
    those HID's are extremely expensive and very hard to find.I'll attempt to find some HID's but if all fails.... I guess it's the Halogen unless there is a alternative that is better other than the HID's.
    So far I need a complete air filtration system including the resonator. I DO need a radiator{old one was bad} A complete front bumper assembly. The fan shroud.
    The rubber wheel well cover for the driver's side is missing. The lower plastic skirt/bib connected to the bumper under the engine.
    I would love to find a prius in the auto salvage yards but I continue to dig deeper and farther and farther away without any luck..This would help with all those missing nuts and bolts and seeing the exact process of assembly giving me a better understanding of how it all goes together.
    Being a first timer on a Prius, it helps to have a duplicate around to examine the entire setup and familiarize myself with it.
    Looks like I can procure some HID's but they are not complete with the Ballast plus cover cap. Wondering how difficult and expensive it would be to come up with those ballast separately?
    IS there anything close to those HID's or are they "One of a Type" ?.... I mean having excellent vision at night can really be worth something.........
  19. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Here in Canada all Prius come with Halogen bulbs and they give off good light. At least I'm not changing them out all the time like some do with HID's. They should out-law those blue lights anyway. Probably cause more accidents than they do good? Hal
  20. uart
    uart Senior Member
    4,215
    1,201
    Australia
    Hi wingding. Even if you can only run it for a few minutes at a time, if you keep it in park and just let it idle then it will charge the traction battery. Try to get it (the SOC indicator) to about 4 or 5 bars (blue) if you can. It might take a few goes but it doesn't take too long to charge a few bars like this.
    BTW. Just wondering, how many bars do you have on the SOC (state of charge) indicator at the moment?
