Brake, ABS, (!) dash lights are lit.
Discussion in 'Gen 2 Prius Main Forum' started by ldome, Jun 20, 2017.
  1. ldome
    ldome Junior Member
    Florida, USA
    Hello all,
    I am driving a 2006 Prius and the BRAKE, ABS, and (!) dash lights turn on when I come to a complete stop.
    The lights do not generally come on immediately when I turn the car on into "Ready" mode.
    The issue always happens when I drive and then come to a complete stop.
    When I turn the car off and then on again, the lights seem to turn off, then once again as soon as I reach a complete stop they turn on again.
    Now, it is only the 3 lights (BRAKE, ABS, and (!)).
    My VSC light has not turned on. I have seen in other posts the VSC light is included in the problem.
    The driving does not really seem to be effected much at all. The brakes still seems to work.
    However, the car manual claims that I need to take it to the dealership.
    Love any information and help on this situation.
    Thanks in advance!
  2. JC91006
    16,673
    8,518
    When was the last time you checked your oil level? Does your AC blow cold?
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    before you do anything have the 12 volt battery checked.. a weak battery throws all kind of codes and warning lights.. when you hit the brakes the brake lights might drain the battery enough to trip the warning lights
  4. ldome
    ldome Junior Member
    Florida, USA
    I had the oil charged about a month ago. Probably only have driven it about 500-1000 miles since then.
    I just checked it now and the oil seems clear and at a good level.
    I have noticed just today that I only have 2-3 bars on the battery icon on the "info" display. (I have not been driving this particular car for a few days due to this dash light issue) Could the battery charge deplete with such minimal driving?
    I just checked on the Aux Battery and it was replaced 6/2016. Seems sort of new to be losing levels.
  5. ldome
    ldome Junior Member
    Florida, USA
    Yes, oil seems to be clear and at a good level. Changed the oil ab out a month ago about 500 mile driven since.
    The AC seems to blow cold too.
  6. JC91006
    16,673
    8,518
    You would need to get the codes read to know the exact problem.
  7. ldome
    ldome Junior Member
    Florida, USA
    Okay. Thanks!
    And could a standard mechanic retrieve the codes? Or does the Toyota Dealer need to do this?
  8. JC91006
    16,673
    8,518
    The Prius has specific codes that some standard mechanic readers cannot read. It depends on their equipment.
    The dealer for sure can do it, just they charge a lot more.
  9. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    12 Volt BATTERY!!!! This is common before 12v. battery bites the dust.
  10. JC91006
    16,673
    8,518
    I actually think this might be an ABS actuator problem, which should be covered under an extended warranty by Toyota (I'm not sure the duration though).
  11. ldome
    ldome Junior Member
    Florida, USA
    I got the codes from the auto part store.
    Hopefully, these test are reliable.
    The codes were C1249 and P1121
    Attached are the photos of the reader.
  12. JC91006
    16,673
    8,518
    You seem to need a new brake lamp switch and a new 3 way coolant valve.......for now
  13. ldome
    ldome Junior Member
    Florida, USA
    Are these repairs/parts pretty easy to do myself? Any references or threads to follow for this one?
    Also, after watching some videos online, I do hear some slight noise while holding the brake down. Sounds like 5 seconds of quick ticking. People seemed to identify this sounds to ABS modules needing to be replaced. Perhaps?
  14. JC91006
    16,673
    8,518
    Both repairs are fairly easy. You will want to do the brake lamp switch first, that's causing the red triangle. The 3 way coolant valve wouldn't affect much, check engine light will be lit with this problem though.
  15. ldome
    ldome Junior Member
    Florida, USA
    Thanks for the replies!
    The red triangle has never been lit nor has the check engine light.
  16. Patrick Wong
    18,200
    6,493
    Very strange, since DTC P1121 is logged by the engine ECU, the check engine light should appear.
  17. ldome
    ldome Junior Member
    Florida, USA
    Do you have any additional thoughts Patrick?
    I do hear some slight noise while holding the brake down. Sounds like 3-5 seconds of quick ticking. People seemed to identify this sounds to ABS modules needing to be replaced. Perhaps? or is this the Brake Actuator?
  18. Patrick Wong
    18,200
    6,493
    I think you should replace the brake light switch and see what happens.
  19. ldome
    ldome Junior Member
    Florida, USA
    Thanks!
    Any idea of resources or videos to use for install instructions and to purchase parts?
  20. JC91006
    16,673
    8,518
    The part you need is called a "stop lamp switch". The OEM switch is very expensive, retails at $63.95. Often sold online at a discounted price around $46.88. Part number 8434047020. I may have a used one for sale if you're interested (maybe)
    Here's the link to Camelback Toyota's page.
    2008 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    Installation is very easy, just need a wrench (10mm I think). Loosen the nut, remove the old part, install new part and tighten the nut.
