Brake, ABS & traction lights, AND a Surprise Bonus!
Discussion in 'Gen 3 Prius Main Forum' started by tonycd, Apr 8, 2023.
  1. tonycd
    tonycd Member
    84
    56
    First the brake and ABS lights on my wife's 2010 came on intermittently. Then the traction control light came on intermittently with them.
    My very capable indie guy is firmly confident the brakes mechanically are working fine. Pulling codes, he saw a 12v fault and faults at 3 of the 4 ABS wheel sensors. He feels it's intuitively obviously that I didn't happen to have 3 sensors fail at once. As for the 12v battery, it was replaced only a year ago and everything else starts up, lights up and runs just fine, so he's skeptical of that too.
    Now the Surprise Bonus I promised: When I drove the car myself, I used the cruise (she never does). It's cutting out intermittently, too. The cruise-enabled light stays on, but it forgets the set speed on the fly just as if you bumped the lever with your knee -- the "Set" light goes out, and the car starts to decelerate. Sometimes it holds the set speed for several minutes without failure. Sometimes it forgets it again and again in seconds. There's no apparent relationship between when this misbehaves and when the brake-related lights misbehave, either.
    Thoughts, O Best and Brightest?
  2. Tombukt2
    Tombukt2 Senior Member
    13,079
    2,344
    Durham NC
    I think the break actuator in the car houses all the computers for the breaking so if any of that would be messing up I would think it might shut off your cruise control just seems like it would follow some logic like that
  3. ChapmanF
    18,263
    He's probably right that 3 sensors failing at once wasn't the reason the detection conditions for those codes were met. It might more likely be an issue in some segment of wiring common to them, or less commonly a problem with the ECU. But why should we be guessing? Is he against going through the troubleshooting procedures, the ones in the repair manual if he doesn't have better ideas, to find out what did cause those conditions to be met?
    Same idea for the battery. It might be just a year old and all shiny and nice, but if that 12v fault (what was it? C1241? always better to say what codes you had, not just paraphrase them) has a freeze frame, the freeze frame will show you what the voltages were when the code was set. They might surprise you. But also, they're measured at the brake electronics. A low voltage there doesn't necessarily mean it was low at the battery. Again, that's what the troubleshooting procedure is to help figure out.
  4. tonycd
    tonycd Member
    84
    56
    I agree about the 12v low voltage fault not necessarily being indicative of a battery problem. I also know various weird behaviors and codes can be the result of low voltage.
    I respect your comment about the troubleshooting process, and I'm sure my mechanic does too -- he's diagnosed a lot of cars. The question that comes to my mind as a starting point is, in the absence of a conventional voltage regulator, what regulates the voltage on our cars?
  5. Tombukt2
    13,079
    2,344
    Durham NC
    A chip in the inverter right. This part goes bad and gets replaced in Gen 3 converters I thought which has no bearing on what's going on here. I'm sure there's a similar chip in the Gen too I don't think we hear about it much because the Gen 2 inverters are pretty dang solid I have several here waiting to go in cars when their originals fail which looks like it may be never.
  6. ChapmanF
    18,263
    It might not have been Mark Twain who said it, but "the things you know that just ain't so" still sums up something to watch out for. Sufficiently low voltage can indeed be the cause of some trouble codes—especially the ones that mean "hey, letting you know the voltage is low over here"—but also gets blamed for a much wider variety of things because it's an easier story to reach for than doing the legwork to find out what's really causing the things.
    The electronics industry has gotten really, really good at voltage regulation. The "absence of a conventional voltage regulator" just means we're no longer stuck with the old metal arm in a magnetic field that vibrates between giving your alternator too much field current, too little, or somewhere in the middle when it's between the contacts.
    The Prius regulates your voltage pretty much the same way every modern electronic device does: pretty accurately, by measuring it, comparing it to the target, and pulse-modulating the DC/DC converter accordingly.
    It also chooses the target voltage according to conditions. It can set the target up around 14.8 if it thinks your 12 V battery is low and could use a bit more charging. It tends to lower the target closer to 13.5 if you're driving down the road and it doesn't think extra charging is needed. It also takes occasional brief samples where it sets the target below the expected battery voltage and evaluates what the battery's putting out. These are more brief than you'd notice, but they show up if you're datalogging the voltage.
    So the voltage is normally pretty well between 11 and 15, which is about what you could count on from the old-school vibrating reeds anyway, and is pretty much the range that any "12 volt" equipment is built to gracefully handle.
    And then within the car's ECUs and similar digital electronics, a local regulator will take the incoming 11-to-15 and produce a rock-solid 5 for the microprocessor circuits, just as in any other 21st century electronic device.
    If you look up the detection conditions for trouble codes, you'll see that the ones triggered by the incoming nominal-12-volts are generally not triggered until it drops below 9.5 or so. The ones that are triggered by the locally-regulated voltages inside an ECU have much tighter tolerances, being set for any deviation a quarter volt above or below 5.
    And that's all interesting stuff that it doesn't hurt to know, but the quickest answers to what's up in your car might still be found by systematically working through the troubleshooting procedures. It's not like those were written by people who don't know how the car works.
  7. tonycd
    tonycd Member
    84
    56
    Another new data point: Found and checked (thanks, Forum!) the procedure for reading the 12v battery's voltage off the nav display. Result: yep, a borderline-subpar 11.2 volts.
    I put up the above sentence before I read your detailed post (thank you for it). From what I read in other threads, the small capacity of the 12v battery and the drains imposed by the voltage test itself (activating the brake master cylinder by getting into the car, flicking on the headlights 4 times) cause a bit of a voltage drain that can cause the readout to be pessimistic by something like 0.7 volt. Obviously that would be consistent with your comment about a rather wide range of voltages being within the range of acceptability, and indeed, the car starts and runs.
