BRAKE ABS VSC lights. ON
Discussion in 'Gen 2 Prius Main Forum' started by mvperaltam, Dec 31, 2016.
  1. mvperaltam
    mvperaltam New Member
    US
    recently the lights brake abs vsc on my 2006 G2 prius turned on, the codes C1241 C1391 C1259 are the result of the scan. Looking for information of those codes refer to a possible problem with the brake pump. I appreciate any guidance that can offer me to solve the problem. Where can I go?
  2. dolj
    dolj Senior Member
    7,653
    3,866
    Wellington, New Zealand
    C1241 Low Battery Positive Voltage
    C1259 HV System Regenerative Malfunction
    C1391 Accumulator Leak Malfunction
    C1241 would suggest checking whether your 12 V battery is in good condition. I'll put money that it isn't. You need to use a DMM (digital multi meter) to check a) the sitting voltage with car off, b) the voltage drop under load and the subsequent voltage that it settles at under load (use the headlights on to apply a sufficient load) in IG-ON (not READY) and c) the voltage when you make the car READY. Be prepared to replace the 12 V battery. Once replaced, clear the codes and take the car for a short drive (if necessary) to see if the other two codes come back – I suspect they will.
    The C1259 is most likely set because of the C1391. Focus on the C1391, there is an extended warranty on the accumulator pump and you should take your car your preferred dealer to see if it qualifies. If it does, it will be fixed free of charge.
    #2 dolj, Dec 31, 2016
    mvperaltam and bisco like this.
  3. mvperaltam
    US
    I check the battery voltaje and this are the value: a) 12,80 b) 12.15 and c) 13,80. That means the problema is C1391 Accumulator Leak Malfunction
    49,488
    b) is low, what were the conditions?
  5. dolj
    dolj Senior Member
    7,653
    3,866
    12.15 V is ok for the load test as long as it held the voltage over a 5 min period.
    Looks like your 12 V battery and inverter are ok (13.8 V indicates the car thinks the battery is on the full side).
    Yes, focus on the accumulator. Have you checked with Toyota whether you qualify for getting this fixed under the extended warranty? Another member just had Toyota agree to cover the repair under warranty, so it would be worth checking.
  6. mvperaltam
    US
