BRAKE- ABS- VSC- Warning Lights = CODE C1344
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jan 7, 2025.
  1. ski.dive
    ski.dive Active Member
    958
    241
    Hutchinson Island,FL. Mt. Snow,VT
    My BRAKE- ABS- VSC- Warning Lights have been on for 3 months now.
    I Finally got a Code Reader- And Got CODE C1344 [ Hydraulic System Left Rear Brake ]
    What needs repairing or adjusted?
  2. Brian1954
    Brian1954 Senior Member
    1,755
    683
    South Central PA, USA
    No one will know for sure until the troubleshooting steps in the Toyota service manual for the C1344 are performed.
    Are you going to try fixing the problem yourself? If you are, get the service manual and start going through the troubleshooting steps. If you are not going to DIY, just take the car to a good service center or dealership.
    dolj likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,954
    1,905
    NJ-USA
    Something with the brake system - specifically for the left rear brake.
    Could be a number of things. Brake fluid leak, air in the system, brake shoes grossly under adjusted, brake actuator fault, etc.
    You need to have the entire braking system inspected by a competent mechanic.
    (personally, I wouldn't have waited 3 months)
    Brian1954 likes this.
