Brake accumulator actuator testing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thefoxman45, Nov 21, 2018.
  1. Thefoxman45
    Thefoxman45 Junior Member
    Kirkville NY
    Is there a way to test a used brake accumulator assembly? If I were to pull one from a car in the junkyard or buy a used unit how would I know if it’s good or bad?
    Are the new replacements a different part number or is there a way to tell if a unit is an updated part? I’m assuming the new Toyota part is an updated version that is not susceptible to failure like the originals.
    Oh, I have a 2007 Prius throwing codes c1256 & c1391.
    Thanks!
    iPhone ?
  2. Patrick Wong
    18,200
    6,493
    It would not be a good assumption to believe the current brake actuator has a lower failure rate than the original design.
    Usually a newer part will have a bigger number on the part number suffix compared to an older part.
    I do not believe there is a reasonable field test other than installing the actuator to see how well it works and how often the pump needs to run.
  3. FatBob09
    FatBob09 New Member
    DFW
