Brake accumulator?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CaliMike, Dec 29, 2024.
  1. CaliMike
    CaliMike Junior Member
    Pasadena
    I've rolled 240K on the 2012 Prius V.
    The issue is an air type noise which comes and goes when on the brakes at stoplights. I don't believe it is connected to a brake motor. It is like a puff air noise or something not to loud perhaps a bit like a seal. No lights have come on. My take is that it is the accumulator and that the ABS has to be replaced. I've also read to swap the brake fluid first that there may be bubbles.
    Has anyone purchased the ABS used or can they reccommend a site where I can buy?
    I appreciate any input.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,165
    6,319
    Texas Hill Country
    A brake fluid flush has been known to clear up a brake booster problem if you get the dealer's $150 Techstream driven version. For one or two days and then it returns.
    If you buy a used booster it is almost guaranteed not to work, either because it is the wrong part number or it has also failed. Verification by donor car vin compared to your car's part found by vin is about the only way to know if a used part is correct.
    A v's brake booster is different than a hatchback even though the housing numbers are the same. In addition there are two different part numbers for a 2012 v.
    I would buy from an online Toyota dealer, ideally during a periodic sale although online prices are almost always 25% less than the local dealer's walk in price.
    With that said, I would verify what you are hearing directly under the hood. I probably would not buy the parts unless you get the code(s).
    Tim Jones likes this.
  3. CaliMike
    Pasadena
    Thanks for your input, I will follow your advice and wait until I get the codes.
  4. rjparker
    10,165
    6,319
    Texas Hill Country
    Part of the advice is to determine where it's coming from. May require one person at the wheel and another under the hood with an auto stethoscope.
    Review this video carefully to help diagnose and to understand the job. It's a big one.
    Pine Hollow Diagnostics
    Prius Brakes FAIL
    Dana64, Tim Jones and Air_Boss like this.
  5. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    Not a shade tree job...
  6. CaliMike
    Pasadena
    I now have the codes. I can't imagine that I'd be covered under phase 2 of what you posted. The car has 240,000 miles. It sure seems like a challenging job. I'm at a bit of a crossroad, I have yet to replace the hybrid battery in the car. While there is some new paint and a new engine, I feel like the suspension could be wearing thin and the front seat is leaking yellow material. I love the car though. It's been a good one.
  7. rjparker
    10,165
    6,319
    Texas Hill Country
    New engine? Or used, rebuilt or just a new head gasket?
  8. CaliMike
    Pasadena
    The engine was replaced for $3000 with a re-build engine at 195K. I also put a cat guard on the car then.
  9. rjparker
    10,165
    6,319
    Texas Hill Country
    Except for the engine, brake booster and soon the hv battery. Apparently the interior was not used "by a little old lady from Pasadena".
    If you have revised pistons and rings in that rebuilt engine it might be worth $2500 now for a brake booster and another $2500 for an oem battery a year from now. As always it depends on your finances. A good replacement might be a 22 Rav4 hybrid with factory lithium battery, bms and advanced safety systems. But that might mean $750 monthly payments or a good chunk out of the savings account. The v will have to go at some point but a quality rebuilt engine which is not burning oil should go ten years. Suspension issues might be simple sway bars.
    Your choice.
  10. CaliMike
    Pasadena
    Thanks for your input, I haven't let go of the Prius yet.
  11. Tim Jones
    Tim Jones Senior Member
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    Has the Inverter blown yet? Very surprised if it hasn't.....
  12. CaliMike
    Pasadena
    I tried to go the used route at my mechanics input for the booster and booster pump. The first one he got didn't match. The second didn't work. Now the first one is back in and the car is working at it isn't making the noise at stoplights. I know a brake flush was done putting it back. Does anyone have input? Is it possible that it lasts a long time?
  13. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
  14. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    Hey guys :) today I drove for the very first time a 2012 V that's been off the road for a little over a year due to head gasket failure, the V is new to me, i got it for a song broken down a while back and its just sat around until today
    I can hear a slight "air/puff" noise coming from inside the driver foot well around the brake pedal region when i press the brakes, wonder if this is the same noise Mike is hearing
    I am sus on the ABS module, maybe im just paranoid? its cycling every other time I press the brakes, without fail every second press with light to moderate force it pumps for about 2 seconds, cant say i have noticed any of our other prius running the pump this often but the wiper cowl is still off the car so there's also a chance i am hearing things that I wouldn't normally notice if properly covered over
    Is there any chance because the car has been off the road for so long, with the front wheel removed and facing uphill the system might just need proper bleeding, or would that just be a waste of time?
    Cheers ..
    Matt
  15. Tim Jones
    1,758
    565
    SE Texas
    2011 Nissan LEAF
    when it's really bad pump runs every 15 seconds...... buzz sound
  16. ozmatt
    637
    263
    Australia
    I don't think it's running too often when not pressing brake pedal, I will take more notice of that from now on. was just a little worried hearing it buzz every second time that I press the pedal
