Brake Actuator/Accumulator Noise on Startup
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, Apr 24, 2009.
  1. Marvinh
    Marvinh Marvin
    189
    NY - Long Island
    I have posted a couple of other threads about noise from the Brake Actuator / Accumulator assembly on startup. And I received differing opinions on whether to replace the pump.
    I recently found the following paragraph in the 2007 Prius owner's manual (page 327) which shows Toyota is aware of the noise, but still put out a TSB on it:
    ' You may hear a small sound in the engine compartment after the hybrid system is started or the brake pedel is depressed repeatedly. This is a pump pulsating sound of the brake system, and is not a malfunction'.
    So what do you do if you hear this noise? I am inclined to leave it alone rather than have a major repair job done.
    Thanks! Marvin
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's normal...
  3. KTPhil
    KTPhil Active Member
    1,379
    I have gotten used to the sound of the Prius Phart.
  4. mathan
    mathan Junior Member
    47
    Toronto
    ROTFL - I'll have to remember that.
