Brake Actuator Assembly
Discussion in 'Newbie Forum' started by LongIslandNY, Jun 25, 2016.
  1. LongIslandNY
    LongIslandNY New Member
    Long Island, NY
    Please tell me what dashboard lights will light if the Brake Actuator Assembly needs to be replaced. The car is a 2009 Prius, so it does not fall in the covered recalls. The car is not making any chirping, whirling, barking or any other sounds that I see other owners hear when they were told they needed this replaced.
    Thank you for any assistance you can give.
  2. Larryy
    Larryy Active Member
    104
    113
    florida
    I'm sure you've figured out by now that Toyota has a warranty extension on this problem. I just got my 2007 fixed for free.
  3. Ellen Berman
    Ellen Berman Junior Member
    16
    Wilmington, de
    Three Touring
    Is there a mileage limit to getting free repairs?
  4. ChapmanF
    15,686
    You'll get the same dashboard lights you get for about 200 other problems in the car. However, once the lights come on, reading the trouble codes will tell you what kind of problem you've got. You can post the codes here if they don't make immediate sense. (The car has several different computers that can report codes, plus they talk to each other, and some of them can report codes that only mean one of the other computers passed along a notice of a problem. So you can end up with more codes set for a single problem than you'd expect, but ultimately making sense after looking up exactly what they all mean.)
    If you have any particular reason to suspect some trouble you're having is brake-related, you're in a bit of luck, because the brake computer is able to blink out codes on dash lights when asked, without requiring any special reader (though a reader can retrieve more detail).
    -Chap
    RCO likes this.
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    its only some cars, you call the dealer and give them the vin number, mine goes in monday but my pump is running alot and i have an error code stored so it should be a free fix, if not its getting junked..not worth a $3000 repair
    RCO likes this.
