Brake Actuator Assembly
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Jon.mason83, Nov 1, 2023.
  1. Jon.mason83
    Jon.mason83 New Member
    TN
    2014 Prius v wagon
    A mechanic replaced my brake actuator assembly and cleared all codes. Drove fine for a week then codes all popped back up again. Took it in again and he cleared the codes again. Only lasted a day this time and all codes popped up again. Brake/ABS/ Skid control etc. Not sure where to go from here to fix this issue. Any advice would be appreciated.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,913
    4,676
    Texas Hill Country
    Used part or new?
  3. Jon.mason83
    TN
    2014 Prius v wagon
    Brand new from Toyota
    V Sport Wagon likes this.
  4. Jon.mason83
    TN
    2014 Prius v wagon
    Mechanic started it up this morning and no lights on working perfectly. Don’t understand what’s going on with it.
  5. rjparker
    7,913
    4,676
    Texas Hill Country
    Alls well that ends well. Codes when it’s alarming would tell the story.
  6. Jon.mason83
    TN
    2014 Prius v wagon
    Well this was helpful
  7. C-in-DC
    C-in-DC Member
    466
    64
    Washington D.C.
    Ask your mechanic for the code info if you get warning lights again. They should also be listed in his invoice for the original work. I’m not a mechanic and I can clear codes with my scan tool. That doesn’t mean the issue has been corrected.
  8. C-in-DC
    C-in-DC Member
    466
    64
    Washington D.C.
  9. C-in-DC
    C-in-DC Member
    466
    64
    Washington D.C.
    Duplicate
  10. C-in-DC
    C-in-DC Member
    466
    64
    Washington D.C.
    Duplicate again
  11. Air_Boss
    Air_Boss Senior Member
    3,939
    1,076
    New Yawk
    Has problem re-occurred?
  12. ChapmanF
    15,402
    Without needing any mechanic or any scan tool, when those lights come on you can get the codes responsible, by doing this:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Then you can post them here, and we'll be able to say useful things.
