Brake Actuator Cycling counts experiment
Discussion in 'Gen 2 Prius Technical Discussion' started by Meter guy, Mar 4, 2025.
  1. Meter guy
    Meter guy Junior Member
    42
    ive been reading the forum off and on for awhile now at the various actuator posts.
    so back in 2020 i took my 09 prius to Toyota to replace the actuator.....3000$ 155K
    previous to that the actuator was running 5-10 seconds every 5 seconds. maybe 6 months ago it got on my minds radar that im hearing cycling again, but its possible its always been there.
    so i installed a counter and hour meter back in late 2024. today im at 274K
    im averaging about 415 cycles per hour, 7500 cycles per tank of fuel and the actuator runs between 2-2.5 hours per tank of fuel. since January 1, the actuator has run about 13 hours total.
    it sounds like its coming on for 2-3 seconds, off for 6 seconds.
    what cycle counts have you noticed on yours? does yours cycle? and when the actuator is working properly, is there any routine cycling at all? when yours failed, what kind of cycles did you observe before the failure?
    #1 Meter guy, Mar 4, 2025
  2. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    I believe that no one pays attention to the cyclical operation of various systems until these systems light up the failure lamps on the dashboard or stop working.
    But if you have such an opportunity, then inform us about changes in operation with increasing mileage of the car.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    If you are talking about the pump in the brake actuator assembly, it really shouldn't "cycle" if you are not using the brakes.
    The pump runs to push brake fluid into a storage "tank" known as an accumulator. Inside is high pressure nitrogen sealed off by a flexible diaphragm.
    Pumping in fluid causes the diaphragm to compress the gas further (an air "spring"). So the brake system has a volume of fluid at a couple thousand psi to use. The ecu controls solenoid valves to direct that pressurized fluid to make the brakes work.
    There's a sensor to monitor the accumulator pressure. When it drops to a certain point (about 3.2V on the scantool) the ecu turns the pump on, then off when it reaches a higher point (about 3.6V).
    Under normal conditions, the only significant "use" of pressurized fluid should occur when you step on the brake pedal. The system will bleed off pressure over time (ie, very slow internal leakage), but that takes place over a few hours.
    On my 2006, accumulator pressure drops by less than 0.1V in 30 minutes (ie, it didn't turn the pump on at all). With "normal" firm brake use, the pump cycles on every 2-3 stops.
    So, are you actually monitoring the correct thing? Personally, I would get a capable scantool to look at the accumulator pressure sensor (ACC in the data list). If it is, then something inside the actuator is leaking.
    Brian1954 likes this.
    51,011
    On a new Toyota hybrid, the pressure must drop overnight, because the pump comes on when you open the driver door in the morning
  5. Meter guy
    42
    Yes I'm monitoring the actuator pump, they are notorious for going bad, it's all over the forum. It's probabally the #1 part removed off of the junkyard Priuses. Ice read that there is an internal leak that drops pressure causing the pump to keep cycling on to maintain pressure.
    I'm thinking about doing a test where I modify the power circuit to supply power when I press the brake pedal and then it can pressurize it when the brakes are needed to preserve the pump and motor. It wouldn't be hard to do. Just create a circuit that engages a relay when the brake is pressed. I'm still thinking about it because I really don't want to spend another 3 grand on the actuator.
  6. dolj
    dolj Senior Member
    8,180
    4,167
    Wellington, New Zealand
    It would be a bit late waiting until you need brakes to pressurize the system.
    I'd think long and hard about modifying a critical system in such a way.
    The OEM design already has checks and balances to ensure the pump does not run more than it needs to. If you have a system behaving usually, you might look into it further to ascertain why that is.
    Brian1954 and MAX2 like this.
  7. mr_guy_mann
    3,939
    1,900
    NJ-USA
    I understand the failure, just surprised that you have problems with a new OE actuator so soon. I see a number of Gen 2 with lots of miles on each (including my own), and none have had this happen - yet.
    I also get the money thing, but what you suggest won't work, because it takes time for the pump to build enough pressure for the system to function. More so when there's "lots" of leakage. You need the brakes to work right when you step on the pedal, not 10 seconds later.
  8. Meter guy
    42
    I'm surprised the new factory actuator is having issues because by 2020 I would think Toyota would have solved that problem, that's why I'm curious if anyone has a properly working system and it still cycles.
    The brake relay to actuator mod would be tested out well before any major road use. I do get what you are saying, needing time to build pressure might not be safe, tho if the actuator only affects the rear brakes as someone indicated, that's only maybe 20% of the stopping power. If I do that mod, I'll report my test results here.
  9. Meter guy
    42
    I'm just concerned the pump will eventually fail from running beyond it's designed limits with all the cycling.
    If I did the mod I would test it out well in a parking lot near me at night when no one is there, that includes getting up to a good speed and slamming on the brakes to see what kind of delay there is. There could be an issue with the computer system too with that mod. If I do it, I'll report the results here
  10. dolj
    dolj Senior Member
    8,180
    4,167
    It is not supposed to cycle the way you describe it. Most of the metrics you listed don't really have meaning to most except 415 cycles per hour is not right if one cycle equates to the normal 3-4 second burst of rattlesnake noise. With the car sitting idle at most, you would expect maybe 1 to 2 every couple of hours. In normal driving a burst every 3 or 4 brake presses plus one when you open the driver's door in the morning and another some minutes after you've shutdown for the day. I do believe that once the car has fully quiesced for the day it does not run the pump again until you next open the driver's door and it will only do that if it needs to. So either you have a problem outside of the ABS unit or your unit is defective – which, as others have said, is uncommon. It's over to you to work out which it is in your case.
  11. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Does the ABS have a serial number, date code, or actual date stamped on it somewhere? I'm wondering if maybe whoever did this service pulled an ancient unit off the shelf. "New" as in "unused", but not "new" as in "recently made".
    I ran into that "ancient unused unit" problem recently with an OEM (really, straight from the manufacturer) "new" laptop battery. It had been made 5 years earlier and was visibly swollen. Of course it went right back.
  12. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    Same as guy mann on a 2012 v with the brake booster assy changed in 2019.
    It would be 3 seconds too late
    You lose all power assist on all wheels plus abs and traction control. Stopping distances would be far longer.
    MAX2 likes this.
  13. mr_guy_mann
    3,939
    1,900
    NJ-USA
    By design, this is a "brake by wire" system. You step on the pedal, and computers decide how to slow the car down. Some regenerative braking. Some hydraulic friction braking. ABS function for the friction brakes as needed. All in a fraction of a second.
    Normally, the hydraulic system is 100% computer controlled and uses the high pressure fluid to do everything. Your foot has no direct connection to the wheels at all.
    There are several levels of reduced functionality depending on what type of fault occurs to the system.
    If there is complete system failure (the pump or the ecu dies), then the final failsafe mode is a direct master cylinder to front brakes connection. No boost, no ABS, no rear brakes (and no regen). This is "pull over right now and get the car towed" mode. Plus constant warning lights and "buzzers" sounding off.
    This is very unsafe to operate as every other car around you is able to slow down MUCH faster.
    I understand the money angle, but either wait until it gets worse, replace the actuator, or get rid of the car.
  14. Hayslayer
    Hayslayer Member
    181
    98
    My daily driver has been running the pump motor with an "off" duration of only 5 seconds and a run time of about 2-3 seconds, since I bought it over a year and a half ago. The 'brakes' have been functioning normally, as it apparently has not failed to the point of causing any problems with the exception of the frequent 'repressurizing'. I'm still waiting to see how long it lasts before it reaches that failure point, and will replace it at that time. Consider it an experiment.
    Meter guy likes this.
  15. Meter guy
    42
    I had it replaced at an actual Toyota dealer. the actuator is buried behind the Inverter so I really can't see any details on it. with as common of a problem this is, i bet their stock was fresh.
  16. Meter guy
    42
    THIS!!! this is the kind of info im curious about from others. THANK YOU :)
  17. ChapmanF
    17,179
    Normal operation is as dolj described it. If you pull into a parking spot and finish a book chapter or a CD you're listening to before turning the car off, you usually won't hear the pump run in that amount of time.
    A car where the pump has to run every several seconds when you're not even using the brakes is a car with severe internal leakage clearly showing—information about how long others have been driving that way might be useful for the strictly limited purpose of guessing how long you might be able to put off fixing something you know is kaput, but that's about it.
  18. rjparker
    9,485
    5,808
    Texas Hill Country
    It seems the forum has an increasing group of owners who bought their gen3 cheap and are now surprised there are some complicated and expensive systems to diagnose and repair. Systems their previous wrenching experience does not help; systems their local garage does not want to work on.
  19. bisco
    51,011
    The group is increasing because the scam artists and defective Prius are increasing
