Brake Actuator Noise in Summer
Discussion in 'Gen 2 Prius Main Forum' started by Marvinh, May 21, 2009.
  1. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Hello - I started a couple of threads during the winter about hearing the brake actuator noise on startup and upon pressing the brake. It makes like a ratchety noise is winter.
    Now that the warmer weather is here I don't hear the noise any longer. What would cause the brake actuator noise to clear up in warmer weather? Is the brake fluid viscosity (or hydraulic pressure) different in warmer weather? And possibly the actuator pump does not have to work as hard to maintain brake pressure in warmer weather?
    So if it only makes noises in the winter, I'm thinking I can leave it alone...because its a 5 hour job to replace the actuator pump and the entire inverter assembly and inverter coolant pump has to be removed (among numerous hoses and connectors). Can you tell I really don't want to do this job? (grin)
    Thanks! Marvinh
  2. Marvinh
    Marvinh Marvin
    190
    NY - Long Island
    Hi its me again. Marvinh. I am re-submitting this thread (note the original date - 5-21-09) hoping someone has an answer this time. Please...:rolleyes:
    Thanks! Marvinh
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My "Chirp" was cured by bleeding the right front brake (by the dealer). The noise is usually caused by air bubbles going through the actuator. See the relevant TSB.
    JeffD
