Brake Actuator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jskee, Feb 3, 2024.
  1. jskee
    jskee New Member
    Long Beach
    2013 Prius Two
    Brake actuator is failing.
    The local pick-a-part has a 2013 Prius V. Are the parts compatible? Thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,900
    4,670
    Texas Hill Country
    A Prius v actuator is not compatible. It may also be bad as these years had brake booster defects. All were covered on a special program for 10 years from first use or 150k miles. They have ecus in them which has different code in a v wagon.
    The best way to check compatibility is via a part number lookup based on the vin. Done on your car and any donor car.
    Hybridpit in Southern California has a rebuild your part service for $550.
  3. jskee
    jskee New Member
    Long Beach
    Ok, thank you.
  4. jskee
    jskee New Member
    Long Beach
    If I'm seeing : C1252, C1253, C1256, C1391 should I be replacing the actuator or the booster and pump?
  5. rjparker
    7,900
    4,670
    Texas Hill Country
    From Toyota program document:
    One or more of the following specific Diagnostic Trouble Codes (DTCs) C1391, C1252, C1256 or C1253 will be stored in the vehicles memory to be used as verification. If the condition is verified, the vehicle will be repaired with new Brake Booster and Brake Booster Pump Assemblies under the terms of this Customer Support Program.
    The actuator, brake booster, abs system or master cylinder are names used interchangeably for the master cylinder assy shown below. The pump is a separate device underneath the master cylinder.
    Both are replaced by Toyota under their 10 years from first use or 150k miles program. Primarily because pumps do occasionally fail and the labor to later remove the master cylinder to access the pump is high.
    Most diyer’s change the master cylinder assembly and not the separate pump to save money.
    You notice in the Hybridpit option in post 2 above they rebuild the master cylinder and not the separate pump. That adds support to the master cylinder assy being more common.
    Finally, calibrating and completely flushing a replaced system requires Techstream or one of the higher end scanners like an XTool d8 or one of the better Launch scanners like the CRP919X.
    If I lived near SoCal I would visit Hybridpit.
    #5 rjparker, Feb 9, 2024
  6. ChapmanF
    15,381
    Back when they had to recall a bunch of the pump assemblies for 2010s, they cooked up some special tools to make the replacement easier without moving so much other stuff out of the way. If you ever have to do it, take a look at the technical instructions for recall D0H for ideas.
  7. Mendel Leisk
    38,614
