brake alarm signal warning but no codes
Discussion in 'Gen 2 Prius Main Forum' started by rogerdpack, Sep 11, 2025 at 4:31 PM.
Tags:
  1. rogerdpack
    rogerdpack Junior Member
    66
    Enoch, UT
    Hello all.
    Accidentally let the brake caliper get pushed all the way out when replacing a wheel bearing.
    Brake alarm sound started.
    Unplugged the 12V so caliper would no longer get pushed out.
    Finished the repairs, replaced caliper, bled it using gravity method.
    No codes seem present, no error lights. Sound remains. I assume the power brakes are off still.
    No codes seem to blink with the "diagnostic" screen (paper clip screen LOL). Doing the "ABS reset" there seems to do nothing.
    Still have the car up on jack stands.
    Any advice? :)
  2. ChapmanF
    17,683
    Do you mean all the dash lights are doing the steady half-second fast blink?
  3. PriusCamper
    PriusCamper Senior Member
    12,277
    4,986
    Pacific Northwest, USA
    If it powers up in ready mode and no codes and lights then jump the two pins with the paper clip routine and press brake pedal 8 times to clear the alarm sound, then take it for a test drive.
