Brake Anti-Rattle Clips ?
Discussion in 'Gen 3 Prius Main Forum' started by Markee, Mar 26, 2023.
  1. Markee
    Markee Member
    325
    50
    South Florida Broward County
    Can someone please confirm the Toyota part number for the OEM brake anti-rattle clips for a 2013 Prius?
  2. Tombukt2
    Tombukt2 Senior Member
    8,909
    1,553
    Durham NC
    No you just look it up on the microfish or whatever the hell computer you use now I mean I can't confirm it but I have a set right out here that I just put on the car that came with my oh gosh Ray bestos I think brake pads. They fit perfectly they come with most pad sets these days If you buy your pads right they usually come with the silver spring clips that hold the pads onto the cutouts or the pads drop into usually you don't reuse those spring clips one fits in the bottom one fits in the top they're not individual per side pieces upper and lower but I have no idea what the part number is The brake manufacturers that are making your pads they don't generally get this wrong
  3. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Go by, or call a Toyota dealership and they can give the correct information.
    Grit and Mendel Leisk like this.
