Brake Booster Program - "Not a Recall"
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Yea Right, Jul 20, 2019.
  1. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    Anyone else receive a letter from Toyota about brake booster replacement that's NOT a Recall ?
    Data Daedalus and bisco like this.
    52,391
    no, does it say what years are covered? can you post it?
    Data Daedalus likes this.
  3. Deoc
    Deoc Member
    70
    39
    Pasco
    2014 Prius Plug-in
    I got the same letter
  4. Mendel Leisk
    41,904
    Try to scan or photograph and post?
  5. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    Sorry for the delay. I'll scan it or photo it tomorrow ... And try to post tomorrow or Wednesday.
  6. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
  7. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Can you provide the rest of the document
  8. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    The coupon at the bottom just references then two versions of coverage, Primary and Secondary, and tells you to put the coupon in your owners manual.
    The very beginning of the letter and the end of the coupon show my car's in-service date (5/14/2014) , my VIN #, and my personal address.
  9. bisco
    52,391
    thanks! i wonder if 2012 isn't covered.
  10. Yea Right
    232
    115
    Seattle
    2014 Prius Plug-in
    I have no idea, but it sure seems weird that this is NOT a recall, yet they will either replace it if you're having issues or reimburse if you already had work done.
    Perhaps there are threshold numbers that determine recall or not.
    For me, I have not experienced any issues with my 2014 PIP.
    ...... Knock on wood :whistle:
  11. Elektroingenieur
    2,515
    3,287
    Three Touring
    Not necessarily. For example, one recall for the 2016 Prius (H0U; see previous thread) applied to only six cars built for the U.S. market.
    The threshold for a recall is established by law. In the U.S., see 49 U.S.C. 30116–30121, 49 CFR 573, and 49 CFR 577; the test is whether a vehicle “contains a defect related to motor vehicle safety or does not comply with applicable motor vehicle safety standards.”
    For problems that don’t meet that standard, automakers prefer to avoid the stigma and regulatory burden of recalls, so they use other words to describe their programs. Toyota’s recalls page, under “Campaign Definitions” at the bottom, briefly defines “Special Service Campaign” and “Limited Service Campaign,” which both involve an inspection or repair of all affected vehicles.
    “Customer Support Program” isn’t mentioned, but the Toyota Warranty Policy and Procedures Manual (available by subscription to techinfo.toyota.com) explains the difference: “Unlike a CSP [Customer Support Program] that simply extends the period of Warranty Coverage (failure of the component must occur for replacement), an LSC [Limited Service Campaign] will allow the dealership to replace/repair the specified component, without a failure, during the allotted time, mileage and/or applicability period.”
  12. John321
    John321 Senior Member
    1,457
    1,405
    Kentucky
  13. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    I got the letter, and I have a 2012.
