Brake Control Power Supply Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ochybridguy, Oct 12, 2014.
  1. ochybridguy
    ochybridguy New Member
    Fullerton, California
    I have a 2004 Prius. I purchased a used brake control power supply and installed it. Does anyone know if I have to reflash it? I tried to relearn the Linear valve offset. I've tried to INITIALIZATION OF LINEAR SOLENOID VALVE AND CALIBRATION with the factory scan tool. I have both. The older one seems to work better when working on Gen II Prius. I also tried to reset the YAW rate sensor.
    C1203 Vehicle Information Mismatch or Engine Control System Communication Circuit Malfunction
    C1345 Not Learning Linear Valve Offset Abnormality
    I'm thinking I have to flash (or reflash) this to the car but I'm not sure. The cost to me is $55.00 to find out so I thought I would ask first if anyone knew.
  2. Patrick Wong
    18,200
    6,474
    DTC C1203 means that the skid control ECU, located near the steering column, needs to be replaced.
    The brake control power supply is basically a bunch of capacitors which attempt to provide power to the braking system for a brief period if the 12V bus voltage drops down, typically because of a failure of the DC/DC converter. There is nothing to flash.
  3. khan
    khan New Member
    pakistan
    i have dtc 1377 & yellow brake warning light on 2007,,,
    what should i do?
  4. Patrick Wong
    18,200
    6,474
    I assume you are referring to DTC C1377. That points to a problem with the capacitor bank which serves as an emergency power supply for the brake system if the 12V bus starts to shut down due to a failure of the DC/DC converter in the inverter.
    First, check the ABS 1, ABS 2 and ABS 3 fuses. If those are good then the brake power supply capacitor bank (located next to the 12V battery) probably needs to be replaced, or there is a problem with the wiring harness leading to that unit.
  5. khan
    khan New Member
    pakistan
    thanks man that helped
  6. khan
    khan New Member
    pakistan
    now there is a loud click sound under the hood when i shift the gear into D and press the P button,,,
    is there something to worry about??
  7. Patrick Wong
    18,200
    6,474
    Before answering that, a few questions for you:
    Was the car in an accident? If yes, what was hit?
    How many problems does your car have?
    Can the car be driven?
    When the car is in P, does the parking pawl at the transaxle hold the car in place?
