Brake Failure/Locked up
Discussion in 'Gen 2 Prius Main Forum' started by 05 Super White Pkg #1 (Ju, Sep 10, 2012.
  1. 05 Super White Pkg #1 (Ju
    05 Super White Pkg #1 (Ju 2012 Prius Four
    vancouver, washington
    Driving yesterday, (slowly down bumpy gravel road). My 2005 Prius locked up, the red BRAKE and the yellow (ABS) indicator lights came on. The car wouldn't go forward or back. I tried setting the emergency brake then releasing it - nothing. Still couldn't go forward or backward. I shut it off, turned it back on, nothing, tried setting the emergency brake then releasing it - I finally was able to drive, but the indicator lights were still on and when I tried to brake, there was nothing, nothing, nothing, then BAM the brakes grabbed and locked up. (This happened several times in a few blocks as I was cautiously trying to test the car out.)
    I parked got out my owners manual which said "STOP, contact Toyota Dealer" so I had my car towed (first time ever for her to be towed) to my mechanic (he's out hunting, so someone else at the shop looked at it.)
    The shop called and said it was showing a code of 1247 and said that it was a "malfunction of the brake pedal".
    They said they cleared the code and the lights went out. Their mechanic is going to take it for a test drive trying several 'braking scenarios'. (they better not wreck my car).
    Anyone hear of this happening before?
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  3. 05 Super White Pkg #1 (Ju
    Towing was free (well... not exactly free: Allstate Road Service). Shop just called, rear brakes were "completely out of adjustment", master cylinder was "overfull".
    They are going to clean and adjust the brakes, take the fluid down to the proper level. $151.48
    They said that if my oil change place had not been refilling the Master Cylinder - my car would have 'told' me that my brakes needed attention (that's how the system is designed to work). I plan on putting a sticker under the hood that says DON'T FILL.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  5. stormtrooper06
    stormtrooper06 New Member
    When I was reading the "nothing nothing nothing BAM" Part I thought you were going to say you crashed! Glad to hear you didnt and that you were able to get it fixed. There is a bumpy gravely road that leads to my home and when I had my Ford Ranger I remember driving down it, pushing the breaks and it doing almost exactlty how you described. The truck had 446k Miles on it. Towed it to my trusted Mechanic cause I couldnt figure it out and he said it was going to cost more to fix it than the truck is worth so I sold it, and Now I am apart of the Prius Crew! I love my 2006 Prius! I love working on cars, and this car is even more fun because its more of a challange! I hope this is a cool Forum and people are nice. Im on other forums for my Dirtbikes and RC cars and there is some Rude, Rude people out there!
  6. richard schumacher
    7,664
    1,047
    United States
    Yeesh! One more reason not to use those Kwiky Loob places.
  7. Christopher Armes
    Christopher Armes New Member
    San Diego
    I'm having the same problem as we speak! ABS/VSC came on and it locked up when coming to a slow at a light. Taking car to the mechanic after work today. Will report back asap.
