Brake Fluid Bleeding
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tok16, Sep 6, 2021.
  1. tok16
    tok16 Junior Member
    Cambodia
    Dear All,
    I'm about to bleed my Prius 2012 plug-in brake line in the rear wheel. I'm curious whether we can do it with the gravity method?.
  2. ChapmanF
    15,496
    A common procedure is to enter "ECB invalid mode" first, so the car will not close valves and thwart you when it notices pressure dropping in that line, then use a good Brake Rock and let the car help you with the bleeding.
