Brake fluid cap missing since mid-October
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by BlueThunder15, Dec 5, 2019.
  1. BlueThunder15
    BlueThunder15 New Member
    Emeryville, CA
    We just discovered the body shop forgot to replace the brake fluid cap on our 2015 Prius III when they completed recent collision repairs.
    They returned the car to us around October 20. We are in the SF Bay Area where the Fall temps have ranged from 35 to 65, with a fair amount of rain. We're concerned water vapor has entered the brake fluid under these conditions.
    Insurance is guaranteeing the shop's work as they are in a contract. We are thinking of having the shop do a brake fluid flush. Any thoughts or recommendations on alternative or supplemental work we should look into?
    Thanks in advance.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    For sure flush it
  3. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Yes, either make them flush it or do it yourself and make sure it’s done right. I haven’t done a brake flush for a while but I think you have to put it in “invalid mode” or similar to flush the brakes, and the body shop won’t know this. Maybe if you tell them the procedure, they’ll do it right, or maybe they’re just a bunch of boneheads who can’t follow simple instructions. I’d say 50-50, which is why I do my own car work.
  4. Mendel Leisk
    41,529
    I'd try to get them to agree to pay for a dealership brake fluid change. Shouldn't be much over $100. Prius brake fluid change is not hard, but it IS tricky. If they in fact lost the cap, why would that make them good candidates for a brake fluid replacement, one that requires invalid mode and knowhow??
    Why the hell would they be taking the cap off anyway?? Are you sure it was them?
    jerrymildred and Grit like this.
  5. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Since there’s not enough info about the collision repair, what if the car was rear ended and the cap fell off and they only repaired the back and was never required to open the hood for any engine work. How are they liable for the no cap?
  6. ChapmanF
    18,250
    I wonder if somebody could do a back-of-the-envelope on the g force involved if the brake reservoir cap "fell off"....
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    A proper brake fluid change IS a flush.
    Any place that asks you to pay extra for a "flush" should be avoided.
    Same thing applies for coolant change too.
  8. Mendel Leisk
    41,529
    It's still iffy that it was the the body shop did that.
    Maybe just fugedaboutit, but do a brake fluid change.
    The cap is not air tight too, makes you wonder what the difference would be.
    Luckily didn't spill, or did some?
    On our 2010 the cap has a bayonet mount, no way it would fling off.
    Watching @NutzAboutBolts doing brake fluid change on his 2012, looks like it pries off? Probably still very secure.
    My hunch: the body shop never touched the cap.
    I DIY'd the brake fluid change a few weeks back (second time), cost me about $15 CDN for 2 pints of of Toyota DOT3. Maybe watch the @NutzAboutBolts a few times, DIY? You could actually do it with the car on the ground, no wheels removed, but it's easier raised and wheels off. My wife helped, pushing the brake.
    #8 Mendel Leisk, Dec 7, 2019
    NutzAboutBolts and Grit like this.
  9. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Same hunch here.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    I picked up a spare for $1 when I was last in the wrecking yard.
