Brake Fluid Change
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by David E. Edwards, Jul 26, 2018.
  1. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    On other cars I have been able to flush the brake fluid by draining as much as possible from the master brake reservoir and opening one or more bleeder valves. While this procedure is going on, keeping the reservoir filled with fresh brake fluid.
    Will this procedure work on a Gen 4 Prius?
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
  3. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    No. Prius brakes are complex. (Regenerative, Friction, Engine,etc.) Whenever the test strips indicate you need new fluid, I would take it to a hybrid mechanic. It is not a 'shade tree' system.
