Brake fluid greenish color, bad?
Discussion in 'Generation 1 Prius Discussion' started by That_Prius_Car, Sep 13, 2019.
  1. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    last December I had the front bearings, rotors, pads, and calipers replaced on my 2002 G1 with 150,000 miles. I also had them replace the brake fluid and it’s now a greenish color which I believe used to be a light tan, after research, apparently it could mean there’s corrosion or...?
    I’m just surprised the brake fluid I replaced not even a year ago is possibly bad. Let me know your thoughts. Here’s a photo.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Although I don't have direct experience with it, I've always heard green colored brake fluid is caused by moisture contamination.
  3. frodoz737
    frodoz737 Top Wrench
    4,734
    2,526
    33
    Flushed once, a year ago, for the first time?
  4. Leadfoot J. McCoalroller
    8,168
    7,673
    Pennsylvania
    2018 Prius c
    Probably best to use a tester to confirm, but to my eye that looks like a photo of water-contaminated fluid. If the cap wasn’t on tight, or if there is some other sort of air leak at the reservoir you can get that level of water absorption in weeks.
    Some brake fluids are dyed for various reasons, but I don’t know of anybody using green dye, because that would make good fluid look the same as bad un-dyed fluid.
    You can get cheap chemical dip-strips to verify water content.
  5. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    take it back to the shop that did the work and ask them about it. If they tell you it's normal, ask to see a container of the stuff they use. I've seen black (contaminated) brake fluid. Seen blue--DOT 5. Never seen green, wouldn't make sense. Maybe someone put coolant in the wrong container?
