Brake issues plus ABS light on
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jaytaco, Nov 21, 2017.
  1. Jaytaco
    Jaytaco New Member
    49,380
    welcome!
    you need to read the trouble codes. how many miles on her? look like your tpms is on as well?
  3. Jaytaco
    Jaytaco New Member
    It has 93,000 miles on her, and Tpms broke a while back
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I had this come on yesterday. I pulled over to the side of the road, immediately shut the car off, opened the drivers door to hear the brake booster pump, then powered the car back on. The lights stayed off... I checked the codes with my code reader and there were none reported.
  5. Mendel Leisk
    38,649
    Insensitive brakes makes me think they've gone into a sorta fail-safe mode, which I've had on our 2010 Prius hatchback, was a "handshake" electronic problem. Never compeletly resolved, but might have been due to my having a Scangauge always weighing on the OBD port.
    Maybe your code reader isn't sufficient, is it techstream? Invest $75~100, bring it into dealership for diagnostic?
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I haven't had the issue since. I'm thinking it's an issue with my drivers door, honestly. I'm having issues with the door lock actuator right now and I know the brake booster engages when you open the door... so maybe?
  7. RedUgPri
    RedUgPri Junior Member
    17
    NY
    Try checking the health of your auxiliary battery. I had a similar problem in my second gen just last week and it ended up being caused by low voltage in the 12v system. The Brake and ABS lights would come on and the car falls back to manual braking, hence the soft pedal.
    ztanos: The failure of your door lock actuator could also be caused by the aux battery. Does it work sometimes?
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Nope. Never. Same as my passenger side door a few months back. :D
