Brake job complete
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by davidhoule, Jan 31, 2017.
  1. davidhoule
    davidhoule New Member
    CA
    Technology
    I am in mississauga south west. My Prius 2012 has 113000 on original brakes. Dealer wants 980 for 4 wheels..Sounds like too much. Any advice?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    100 if you do yourself
    51,140
    welcome!
    did they give you the pad measurements? do you need rotors? are they working okay? making any noise?
  4. Kenny94945
    Kenny94945 Active Member
    842
    418
    Sausalito
    2016 Prius v wagon
    Need a price breakdown to comment on dealer price.
    What labor rate for example?
    Are your rotors worn out or still within spec?
    Do it yourself is the most economical.
    2 ft rotors
    2 re rotors
    pad set
    brake flush
    emergency brake adjustment
    caliper pin replacement - seems to be a known issue.
    inspect/clean or replace caliper piston boots - always caked with brake dust and possibly dried out.
    inspection and grease or replace wheel bearings (needs new seals) - I also think the wheel bearing are a known weakness - yet I am unsure.
    Don't forget a proper bedding procedure!
    For DIY I also believe there is a special procedure to disconnect the ABS computer - yet I am unsure.
    I believe one is to disconnect the 12 volt battery before brake replacement.
    I am also unsure if a Toyota Handheld Scanner is required to open any brake circuits or reset systems.
    Also not sure of any special tools required, yet a caliper piston retractor may be helpfull.
    (Rant - I sure wish Toyota sold a service manual other than on-line subscriber fee access)
    The above list would be a start as to what could be required.
    Good luck in your research/ decision.
  5. Mendel Leisk
    40,574
    I'm not sure either rotor or caliper pin replacement is warranted. If the rotors are in good shape, and nowhere near mininum thickness, why replace??
    I've done rear's (long story). The pads were just under $100, and shims under $17. Replacement of the latter was not really warranted, but they were so nice and shiny. :)
    I would expect front pads and shims would be about the same, maybe a bit more. So, front and rear pad and shim cost: $250~300, at most. This is Toyota parts, through the dealership, in Canada, the home of inflated prices.
    So, front and rear brake job, just cleaning everything up, relubing the pins, putting in new pads and shims: $400~500 would be reasonable.
  6. mrbigh
    3,686
    699
    Long Island, NY
    It is an steep price, are you getting replacement of what?????
  7. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    Search for Nutz about Bolts DIY videos here, or on YouTube.
    The car can be treated like any other, in terms of brake jobs, once you put the car in a special mode. Almost $1000 is INSANE for a brake job.....crook dealer
    #7 Jimi1976, Feb 1, 2017
  8. ETC(SS)
    6,953
    If you don't have the ability to do the work yourself, see is a brake shop or an independent mechanic will do the work.
    Since every other car in CA is a Prius, I'm thinking that getting a lower bid should not be a problem.
    As stated above, $400-500 would be the most I would pay for this service IF DONE CORRECTLY, and for less than $100 in parts you can do it yourself.
    Good Luck!
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Sure they do. A LOT of places try to sell you a complete brake system rebuild whether you need it or not.
    Chances are that all you need is new pads. On a car that old, if not driven in a winter salt bath, the rotors and calipers probably are still good for another 100K.
    Ask them exactly what NEEDS to be done and why.
    Then get a second opinion.
