brake light not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sockmonkey, Aug 12, 2013.
  1. sockmonkey
    sockmonkey Junior Member
    84
    texas
    Hi I am having an issue with my prius 2006 brake light ONLY the (LED'S) is there a way to test it to make sure that the led's are infact working and its not a fuse or wiring issue that is causing them not to light up? a less costly DIY?
    If not I can always purchase that part (since the outer plastic casing got cracked by a shopping cart) and install it myself with the youtube videos. I don't have the funds to put towards a whole new tail light assembly at the moment. So, I would love other suggestions if any one has any. Thank you! :)
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This is the Prius C forum, you might have better luck in the Gen 2 forum, but it is rare for all of the LEDs to go out at the same time, sounds like a wiring issue to me, or maybe a fuse.
