Brake Lights Come On With Side Markers -- Vice Versa
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by WhoIsJeremy, Jan 9, 2023.
  1. WhoIsJeremy
    WhoIsJeremy New Member
    Baltimore, MD
    2014 Prius c
    I'm truly stumped on this one and can't seem to figure out anyone who's had the same issue.
    I let my brother drive my 2014 Prius C for an extended period of time because it was my extra vehicle. He called me one day and said he didn't have brake lights, so I walked him through how to check the fuse, which was popped, and how to replace it.
    About a week later, he calls me again and says every time he hits the brakes during the day, the interior lights dim. My immediate thought was there was a weird wiring issue and the brake lights were pulling too much. Come to find out, that's not it at all.
    When the brakes are hit, all of the lights on the circuit come on. Brake lights, tail lights, license plate lights, and side markers (side marker lights turning on automatically causes the gauge/radio lights to go to night time mode which is why they were "dimming" during the day.)
    When you turn the side markers on via the headlight switch, again, all of the lights come on including the brake lights.
    To try and rule out a short in one of the bulbs, I've unplugged every light from the circuit and unclipped the headlight switch wiring, and it's still doing the same thing.
    If I pull the 10A fuse from the fuse box labeled "TAIL" and turn the headlight switch to "side markers", none of the lights come on. If I hit the brake pedal, all of the same lights come on, but the gauge/radio lights don't dim.
    Any other thoughts?
    49,490
    rodents?
  3. Elektroingenieur
    2,515
    3,259
    Three Touring
    A defective connection between the left or right rear combination light assembly and body ground points M1 or M2, respectively, could let the stop light circuit back feed the illumination and tail light circuit. I’d start by checking for continuity between body ground and terminal 1 (white wire with black stripe) on connectors M5 and M6 at the rear combination light assemblies. In the Electrical Wiring Diagram (more info), see the “Stop Light” and “Illumination, Taillight” pages of the System Circuit section.
  4. WhoIsJeremy
    Baltimore, MD
    2014 Prius c
    Just checked and there's continuity between body ground and all of the connectors at the rear combination light assemblies.
    Looking further into the wiring diagrams, how are the parking lights and side markers coming on at all with no TAIL fuse?
  5. WhoIsJeremy
    Baltimore, MD
    2014 Prius c
    I think I found the culprit.
    Thoughts on best way to replace this without having to buy an entire harness? 325492553_620168773108787_8108076585241415453_n.jpg
  6. Kerrynzl
    Kerrynzl Junior Member
    New Zealand
    2016 Aqua
    Unplug it , and use a needle to "de-pin" the plug, [one wire at a time]
    Then solder replacement wires to the indivedual damage wires , and slip some shrink sleeve over the joins.
    then re-click the pins back into the plug.
    If the wires aren't briken you could simply de-pin them and re-insulate with shrink sleeve.
    Also liquid electrical tape is useful if you cant shrink sleeve repairs.
    I've had good luck with our local "U-Pull" with some cutters , gettingplugs with pieces of wire and the correct pins for patching electrics.
    Toyotas a reasonably "universal" with some of their pins, it is usually the plastic plugs [M & F] that change.
  7. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    Where is that wire located? i wonder how that happened.
  8. ChapmanF
    15,615
    I also would wonder why it happened. If it looks like the insulation was chewed off, that's one thing. If it looks like it was melted off, then this wasn't the first problem back there, and the first was probably another short somewhere, maybe still needing to be found.
    As for repairing it, the way to do it to Toyota's standards would be to look up that connector in the wiring diagram:
    Toyota Service Information and Where To Find It | PriusChat
    and get the part number of the repair terminals used in it. This post shows how that's done, and how what you find there also shows how the terminals are released from the connector housing (there's usually a primary and a secondary lock, and the primary is sometimes part of the terminal and sometimes part of the housing) and what crimp sleeves go with it.
    You only need as many repair terminals (and as many sleeves) as wires that are damaged; the ones that aren't damaged can be left alone. Each repair terminal has a length of wire already attached, so you can cut back the original wire to a spot that's good, and crimp it to the repair wire at that point. Then you just click the new terminals into the right positions of the housing.
    The reason auto/marine/aerospace industries use crimp connections in a location like that, rather than solder, is that the wire harness there can be subject to vibration, and solder wicking along the wire makes it stiff. (They do, of course, use solder in lots of places where that isn't an issue, like on circuit boards inside modules where everything's fixed in place. Just not where the wiring gets shaken.)
