Brake lights on dashboard
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Nov 20, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    stopped at a rest stop a few days ago.
    creepy car pulled up next to me before i took a nap.
    not sure if i put it into d and inched up away from the person and left it in d. i think the park brake may have been on.
    when i woke a while later, all of the brake lights and anti skid were on (photo in next post)
    i tried to cycle the power, pump the brakes, cycle the park brake etc.
    looked up code scanner - no codes. reset anyways.
    nothing has worked in terms of removing the lights.
    the brakes seem to work fine.
  2. Ben Schneider
    central florida
  3. Ben Schneider
    central florida
    tpms is off anyways
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Prob bad wheel bearing
  5. anonymous
    anonymous Member
    177
    99
    US
    There definitely must be codes somewhere, but probably not in the engine control module; you need to scan the other modules like ABS module or whatever you can access. Might need a better scan tool if it can't access all modules. But I'm pretty sure at least the yellow ABS light means theres an error code stored, if it stays on in READY mode.
  6. ChapmanF
    18,547
    It's sometimes handy, when no suitable scan tool is nearby, to get the brake system trouble codes using a short piece of wire and counting light blinks, as many posts here detail.
    Funnily, there are also lots of posts that are almost the same, and explain where the diag port is, and where to touch the wires, and which pins, but only as a way to clear the trouble codes.
    ... which, of course, is like leading your horse all the way to water, and then saying don't drink! ....
    dig4dirt likes this.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,734
    1,771
    Bay Area
    Did disconnecting the battery and reconnecting it helped?
  8. Ben Schneider
    central florida
    thank you all for your good advice...
    i was called out of town and lost track of this post
    finally got to tampa hybrids... tj used a toyota scanner and found code 1391, brake pump
    tj rightly convinced me the pump is still under warranty and i got it fixed under warranty at the local toyota.
    Paul33570 and jerrymildred like this.
