brake lite on, abs lite on, VSC lite on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jtuchol, May 30, 2013.
  1. jtuchol
    jtuchol Member
    141
    whitehouse,ohio 43571
    got this 05 prius keys stolden( long story) got keys made kind of half nice person work ( smart key feture won't work) and noticed all of theses lites on tried to clear codes by disconnecting 12v no work, an sugestions?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
  3. jtuchol
    jtuchol Member
    141
  4. nh7o
    1,686
    340
    Hawaii
    Look at the GIF attached to that post in the link.
  5. jtuchol
    jtuchol Member
    141
    WELL I JUST DID THE TEST AND NO GO THE LITES CAME BACK ON, HERE IS THE FLASHES I GOT....THE XPLANATION SMYBOL A 95 &66 THE ABS BLINKS 42 VSC 45 DID THE DISCONECT OF THE NEG. CABLE NOTHING, I TRIED THE PROCEDURE A COUPLE OF TIMES OFF FOR A SECOND THEN BACK ON. THE BRAKE LITES WORK AND THE INVERTER PUMP WORKS LIKE A CHARM, BY THE WAY WHEN I BOUGHT THIS CAR IT WAS IN A MINOR FENDER BENDER NO BAGS BLOWN , NO GLASS BROKEN OR OTHER STUFF CAR RAN AND DROVE AND THEN SOMEONE STOLE THE SMART KEYS HAD SOME MADE AND THEY WORK BUT SMART KEY PART OF IT DOES NOT, DON'T KNOW IF HAS ANY THING TO DO WITH IT BUT THOUGHT I WOULD MENTION IT. WHAT NOW? P.S. THE VOLTAGE ON THE 12V IS 12.25 OFF 14.25 RUNNING
  6. Patrick Wong
    18,200
    6,493
    The ((!)) warning light is the Brake Control warning light. The 95 flash pattern means that the skid control ECU has failed and needs to be replaced. The linear solenoid valve also will need to be initialized and calibrated after ECU replacement (that is what the 66 flash pattern means.)
    I suggest you confirm this by taking your car to your local Toyota dealer for diagnosis.
  7. jtuchol
    jtuchol Member
    141
    ok, thanks I will do that I have to figure out why smart key does not work too.( I will have them look at both issues) there is a tech. bulletin out on this problem I just read.
    ok,update! took into dealer and he told me hybryd battery shot I ask him if it was under warranty ( you thought he would of looked it up) so he did and said I had a month and half left on my warranty! go figure , I can't belive it ! so I got a new battery from toyota, cured the problems. thanks to the chat fourm.
