Brake noise, do you have it too?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zerkster, Aug 16, 2006.
  1. Zerkster
    Zerkster New Member
    SanDiego
    Hello everyone I am experiencing a noise that sounds like it might be comming from the master cylinder in the braking system, but i am not entirely sure.
    the noise happens seemingly random but i am always braking a motor noise of some sort.
    I can't hear it in my friends 06' Prius package 8 but i definately hear it in mine 06' package 3.
    Any ideas what it is? Am I paranoid or is this somthing i should be concerned about?
    It sounds similar to the "whirling/click noise" post however this isn't a click noise...
    http://priuschat.com/index.php?showtopic=22460
  2. RichBoy
    RichBoy New Member
    189
    I would recommend you take it to your Authorized Toyota Dealer for proper diagnosis and repair if necessary.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Oh f'krissake. Dealer, schmealer. In support of possibly one of the
    most common newbie questions -- if anyone with fewer than, say, 100
    posts asks this, then it's the accumulator pump, period. If the
    poster says "I know an accumulator pump when I hear one and this
    ain't it", then start worrying.
    Zerk -- it's the accumulator pump. Translation: braking is done
    "by wire", meaning that your foot doesn't push hydraulic pressure
    out to the wheels but a bunch of electronics and valves do. But
    that system has to get pressure from somewhere, so what the Prius
    has is an electric hydraulic-fluid pump that builds up a bunch of
    pressure and holds it for whenever it's needed. As that pressure
    gets used up or bleeds off, the pump automatically runs to keep
    it up to a usable level.
    If you want to hear a lot of the same noise, stop the car someplace
    quiet and pump the brake pedal slowly but firmly, up and down.
    You'll hear a whole lot of pump activity as it keeps up with usage.
    You may also hear a burst of it just when you put your foot on the
    brake to turn on the car, too.
    Now, after all that, if that *isn't* the noise you're hearing,
    suddenly it gets more interesting...
    _H*
  4. loopyloops
    loopyloops New Member
    34
    <div class='quotetop'>QUOTE(hobbit @ Aug 18 2006, 07:47 PM) [snapback]305650[/snapback]</div>
    Just got mine, and I hear that noise, too.
